Cheaply Made Boxes Made By Me
Old Apr 7, 2008 | 05:46 PM
01silvtiby's Avatar
Vehicle: 01 / Hyundai / Tiburon
just want some opinions
i made the boxes out of some wood lyin around and made some fiberglass sealant up
and my amp that someone gave me
Old Apr 7, 2008 | 06:16 PM
LexOne's Avatar
Vehicle: tiburon SE 2000
why did you use press wood?
Old Apr 7, 2008 | 06:26 PM
Caj Darkmoon's Avatar
'press wood', otherwise known as OSB or Oriented Strand Board, will sound like crap compaired to MDF or a decent hardwood plywood.
Old Apr 7, 2008 | 06:40 PM
dood... hope that was just for fun.. if you use that, itll sound like crap and hold up like crap.
go spend like 20$ on some MDF and make it out of that..
Old Apr 7, 2008 | 06:44 PM
Paul J. McCain's Avatar
Vehicle: 2003 Hyundai Tiburon
that's going to sound terrible...
Old Apr 7, 2008 | 07:54 PM
01silvtiby's Avatar
yeah it was just testing to see what would happen. had the wood lyin around so i used it up
Old Apr 7, 2008 | 07:58 PM
hey, you've gotta start somewhere. Good job
Old Apr 7, 2008 | 08:06 PM
tibbymat's Avatar
although its put together well.. particle board leaks like a sif and with enough pressure opens up little slots everywhere. its deffinately not designed for sound pressure! thats why MDF is the best for it. if ur converned about weight then there is also light weight MDF
Old Apr 7, 2008 | 09:47 PM
01silvtiby's Avatar
thanks guys, yea ill be remaking them with better materials. It was just to see if i could fit them and have a good amount of trunk space still. If the box is really small how much will it effect it?? because they are pretty small boxes to fit in the cuby holes in the trunk
Old Apr 7, 2008 | 11:52 PM
aknapp11's Avatar
Check out the manual or somewhere online to get the specs on ur subs. to see how much air space is recomended. im not sure exactly what happens when u use a box that is too small but i think the sub will but out less low frequenc bass... someone correct me if im wrong.
