Cap question
I'm looking at a 1 farad cap for my system.
2 questions about this.
1.) Can I just use the 1 farad and put it before my distribution block?? (as close to amps as possible of course)
2.) OR should i just get 2 .5 farad caps and have them after the dist. block???
my amps are 300w rms and 240w rms respectively.
No, he is asking if he should use a single 1F at the input of his dist block to feed 2 amps, or use 2 seperate .5F caps at the output.One .5F for each amp.
Ohhh..........and that 1F per 1000W is 1000Wp.Just wanted to make sure every one understands that. wink.gif
QUOTE (MADTIB)
CorrectQUOTE
Whats 1000Wp???1 Farad per 1000w RMS or TOTAL?
Also, i will be running power down the drivers side and put dist. block and cap on that side also, directly behind my sub amp. How will 2.5 - maybe 3 ft affect performance to my amp for my front and rears???
