brake lights are on, but shouldnt be
Re: FS: BBTB
I would double check all your fuses anyway just to be sure they are all ok. I found that some of mine blew after fiddling around with wires and such.
Re: Strut tower bar
QUOTE (01roller)
hmm i didnt put that back on cuz i wanted to make sure that everything was working before i put it all back together, thanx..... will try it tomorrow
If you don't put the rheostat (dimmer control) back, it won't light up the cluster smile.gif
Doesn't complete the circuit
I've done it a few times myself too, when I put my gauges on and when I was painting my bezels. I put the gauge cluster back in and then turn the lights on, and nothing,... I was like WTF! But finally realized what I did, or didn't do wink.gif
Re: Stuffed Clutch?!
Also, make sure the headlights are turned off before re-connecting the dimmer switch. If you connect it with power on, you WILL blow the switch.That's what happened to me.
Re: brake lights are on, but shouldnt be
Yeah I found that out the hard way. I thought nothing was working when I installed my new gauges and ripped everything back apart before I tried attaching the dimmer switch.
Re: David from Kspec.com OWNING a GK.
QUOTE (UltraTibby)
So did I , I was so pissed off when I put it all back together and the lights wouldn't work. After a couple of beers, I realized that I forgot to plug the dimmer back in.
Vehicle: 2004 Acura TL
Some funny jokes NWS
Same problem for me but it was with respect to the turnsignals, and brakelights I think...... I forgot to plug the 4-way button back in.
Vehicle: 97 Tiburon
Re: winter tires final choice Questions
you'd be lost in a see of cluelessness...
it's weird that it took you this long to realize it though. lol.
