blown fuse...but where???
Old Apr 16, 2003 | 11:22 PM
ONLY1DB's Avatar
Default blown fuse...but where???
okay i have no
interior light
trunk light
clock
dinging when the key is in the ignition w/door ajar
seltbelt dinging when taken off and car still running
i tried pulling all the fuses but they all look okay...and the fuse box itself really doesnt have too many lables with what is what....so any help would be greatly appreciated!
Old Apr 16, 2003 | 11:50 PM
the backside of the fuze door has the labels as to what they do. If they look good, test them with a multi-meter just to be sure.
There is also a fuze comparment in the engine. Check that one for blown fuses as well.
Old Apr 17, 2003 | 05:59 AM
ONLY1DB's Avatar
i did that and i replaced the fuse that says clock...and some other stuff ....but nothing happens!! no of the fuses are blown or atleast appears to be blown....i guess i will have to take the voltmeter out.... beat_dow
Old Apr 17, 2003 | 09:59 AM
GreatLakesTib's Avatar
i Had the same problem....it is one of the fuses in the driver side fuse area...not sure whic on but it was one that was not labeled for anything that was not working. I just too a good fuse and started replacing all of them till i found it
Old Apr 17, 2003 | 11:13 AM
xxxmonoxidechild's Avatar
hey, i got quoted, rock on!!!!
i feel all special now. all fuzzy and ****.
Old Apr 17, 2003 | 11:18 AM
DJ Nogo's Avatar
xxxmonoxidechild:
only b/c u are a brown-noser tongue.gif off_topi
back on topic...yeah i'd check all the cabin fuses, and if it's not that, i'd put a 90% chance on it being one of the turn signal fuses if it's one of the engine bay fuses, whichever one is used for the interior lights...it's the left turn signal for me, but yours could be different, so check both in the engine bay.
Old Apr 18, 2003 | 12:28 AM
SomeFReaK's Avatar
Vehicle: was 01 accent gs
that fuse is under the hood, there is 2 X 10amp mini blade fuses from memory.
edit - sorry, just noticed you have a tib, the above is for an LC accent.
[ April 18, 2003, 07:29 AM: Message edited by: SomeFReaK ]
Old Apr 19, 2003 | 12:17 AM
ONLY1DB's Avatar
yeah replacing them all was the logical thing...but i was wondering if anybody knew the exact fuse....o well...
monoxi......i just needed a good sig!! fyou_hap wiggle_m
Old Apr 19, 2003 | 02:48 AM
DJ Nogo's Avatar
http://www.hmaservice.com/webtech/iindex.a...1484#_394881484
Old Apr 20, 2003 | 01:12 AM
ONLY1DB's Avatar
even those diagrams dont tell me what fuse if for the dome lights!! .....i dont know. poke
