Best way to wire up my Audio setup and Setting LPF and HPF
Old Jul 5, 2013 | 04:13 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default Best way to wire up my Audio setup and Setting LPF and HPF
New setup. (trying for better sound quality not loudness)
(headunit) Alpine Headunit (50x4) (2 Preout) (Front & Rear)
(Subwoofer & Amp) 800Watt RMS AMP Driving 2x 12" @ 2Ohms pioneers sub-woofers.
I have x6 5.25"
Speakers Specs
13cm (5.25") 2 way speaker
Peak power: 105 W
RMS power: 35W
Sensitivity: 93 dB (2.83V/1m)
Frequency response: 70 ~ 20 kHz
Mounting depth: 53 mm
Voice coil: 4Ī©
Proprietary Plus One« cones
Vented woofer motor structure
Titanium-laminate tweeter
Improved I-Mountā„¢ (patent no. 5,859,917) tweeter-mounting system
Sold in pairs and supplied with grills
i have a 4 Channel Amp.
Specs.
RMS Power Output (Watts x Channels) 75 x 4
Peak Power Output (Watts x Channels) 150 x 4
Power at 2 Ohms (Watts x Channels) 100 x 4
Bridged Power (Watts x Channels) 200 x 2
In case your wondering i fitted the other pair of 5.25 in rear door cards, I may also cover the rear quarter of the door in the acoustic carpet because when i test fitted some it looked really nice half black. It was a bit of pain because i needed the height because of power window bars
Old Jul 5, 2013 | 04:18 PM
Antonyr123's Avatar
I was thinking of Running Front RCA to Control the Fronts only. Then Use RCA splitters to Control the Rear doors and OEM rears Amp & Sub woofer amp.
Because im using 2 Amps. It would be best to tune the mids first using the built in Crossovers & Head unit Balance i want between the speakers. Then use the Amp Sub woofer gain to match ?
