Best way to wire up my Audio setup and Setting LPF and HPF
New setup. (trying for better sound quality not loudness)
(headunit) Alpine Headunit (50x4) (2 Preout) (Front & Rear) (Subwoofer & Amp) 800Watt RMS AMP Driving 2x 12" @ 2Ohms pioneers sub-woofers. I have x6 5.25" Speakers Specs 13cm (5.25") 2 way speaker Peak power: 105 W RMS power: 35W Sensitivity: 93 dB (2.83V/1m) Frequency response: 70 ~ 20 kHz Mounting depth: 53 mm Voice coil: 4Ω Proprietary Plus One« cones Vented woofer motor structure Titanium-laminate tweeter Improved I-Mount™ (patent no. 5,859,917) tweeter-mounting system Sold in pairs and supplied with grills i have a 4 Channel Amp. Specs. RMS Power Output (Watts x Channels) 75 x 4 Peak Power Output (Watts x Channels) 150 x 4 Power at 2 Ohms (Watts x Channels) 100 x 4 Bridged Power (Watts x Channels) 200 x 2 In case your wondering i fitted the other pair of 5.25 in rear door cards, I may also cover the rear quarter of the door in the acoustic carpet because when i test fitted some it looked really nice half black. It was a bit of pain because i needed the height because of power window bars :) http://i39.tinypic.com/72y6o1.jpg http://i42.tinypic.com/2i9gzex.jpg |
I was thinking of Running Front RCA to Control the Fronts only. Then Use RCA splitters to Control the Rear doors and OEM rears Amp & Sub woofer amp.
Because im using 2 Amps. It would be best to tune the mids first using the built in Crossovers & Head unit Balance i want between the speakers. Then use the Amp Sub woofer gain to match ? |
