Anyone know the best ground location in the back of Tibs?
Old Jul 1, 2004 | 08:04 PM
tibu971.8L's Avatar
I know there are some "Ground Sniffers" out there that can tell you the best ground location of your car, but alas I don't have one. I was wondering if someone had located the best or close to the best ground location in the trunk area of Tiburons? A pic would be great.
Old Jul 1, 2004 | 08:34 PM
MADTIB's Avatar
I have mine in the spare tire well.Works perfect.
Old Jul 2, 2004 | 10:04 AM
After I put in my auto antenna, I found a really good ground with a bolt/nut near the stock antenna pole.
Old Jul 13, 2004 | 06:25 PM
Tucker's Avatar
I used one of the bolts just under the backseat for my amp.....maybe you should look around there
Old Jul 13, 2004 | 06:40 PM
4U2enV's Avatar
seatbelt bolts, seat bolts, or just drill a hole in the floor, sand it to bare metal, and screw in your ground.
Old Jul 13, 2004 | 06:41 PM
KayJai's Avatar
QUOTE (joe_the_canadian)
DITTO!
Old Jul 13, 2004 | 07:26 PM
sdtiburon's Avatar
Yep the seatbelts bolts work perfect for the 4 gauge ground wire. First it's hidden under the seat and second it has a huge metal bolt with metal chassis to ground it so the amp will never loose contact!!!
Old Jul 20, 2004 | 11:10 AM
JonGTR's Avatar
I grounded my amp to the strut tower bolt. I grounded my battery to the center screw that the spare tire ties down with. I grounded some neons to the rear seat center bolt. Need more?
