12v Switchable Acc From Hu Problem
Well I'm not recieving any power to my HU. I checked the HU fuse and the one near the clutch and they are both good.
I grabed an old school voltmeter and I touched the postive to the 12v constant (R/y) and the negative to the 12v Switchable acc (B/W) and the power level is low.
I tried grabbing a little bulb and touch each side, and it didn't light up.
Also I only get power if I connect 12v constant from HU to 12v switchable wire from the car, and 12v switchable from HU to 12v constant from car.
Any idea whats going on?
Sorry if this is confusing.
no man, touch the positive meter lead to the constant power wire, and the negative lead to any ground spot on the car. then, do the same with the switched power wire, turning on the ignition to make sure it gets power when it should.
