*HELP* parking light wire / alarm
Old May 22, 2004 | 02:49 PM
canadianshark74's Avatar
I installed my alpine alarm last year. I was never able to find the wire that operates the parking lights. Today I was looking again for the wire. I had one side flashing, then the other side, but I can't find the wire that will flash all parking lights. I tried almost every green/white wire under the dash and all the red wires in the steering column trying to get them to work. still not working. here is what i have found so far:
PARKING LIGHTS +|green/white | |gray 20 pin plug, pin 11 *2 |
*2 The plug is below the cross member beam under the driver side dash.
and
PARKING LIGHTS -|red | |steering column
I hope that someone can look under their dash and tell me where they hooked up that wire, it is really pissing me off now.
thanks guys.
Old May 22, 2004 | 03:56 PM
Default Done! Brakes fixed!
so you're just looking for the wire that your alarm will ground when you press the button right, and then turn on all the lights correct?
i just looked on webtech, and the wire that operates the tailamp relay(threough the multifunction switch) is a red/black wire coming off the multi switch. when youre alarm grounds that, your lights will flash.
Old May 23, 2004 | 08:30 AM
i tried that wire, it comes off the headlight switch, right?
i tried almost every wire in the steering column. and couldn't get all lights to flash.
yes there is power coming out of the alarm wire, i checked that.
still frustrated.
could I just hook the wire into the Hazards? if so where to do that? hmmm
Old May 25, 2004 | 06:18 PM
do you have an online manual i can look at?
Old May 25, 2004 | 08:48 PM
no i don't , i lost the manual for my alarm when i moved.
but I remember the parking light output was (-) if that helps.
Old May 25, 2004 | 09:45 PM
check on here under tech center. do you know the model number?
http://www.alpine-usa.com/
Old May 26, 2004 | 04:26 AM
yeah, i was on that site, i downloaded the owners manual, but no help.
the model is SEC-100S
Old May 26, 2004 | 10:34 AM
ok, this is what you gotta do. that wire is actually a + wire, so you have to buy a relay. this will do fine...
http://www.allelectronics.com/cgi-bin/cate...-643&type=store
look at the numbers here, and then read what i write.
http://suvlights.tripod.com/suvlightscom/h...-boschrelay.htm
tap into the wire i listed in my first post. the red/black one. connect that to terminal 87a. connect terminal 30 to ground. connect the parking light output on your alarm to terminal 86, and terminal 85 to ground.
Old May 26, 2004 | 06:36 PM
AzNxSandMan
Member # 435
posted March 29, 2004 02:35 PM
Finally got a warm day here so I had time to play with this.
The whole time I was trying to find a wire that would turn on the parking lights when hooked up to a positive 12v feed. Didn't find one, so I went back I started to read the install manual over and found that there's a negative parking light output.
What you'll need to do is hook up the (-) light output on your alarm to the (-) parking light wire, this will be the red/black wired located at the headlight switch.
Good luck and have fun.
That was posted on HA. I hope this can help.
