Window Fell Through Door
Old Jan 12, 2005 | 05:50 PM
DarkShark's Avatar
I recently had this happen to me when I was out driving the other day, went to roll down the window and it just dropped through. I looked at the cables and they are all destroyed and frayed. I contacted the local hyundai dealership and they said they could do it for $329.00 + $41.00 for them to look at it and determine if indeed it is the window regulator.
Old Jan 12, 2005 | 06:27 PM
Call and ask if they will do it if you supply the parts.
This IS covered by your warranty.
Old Jan 15, 2005 | 03:56 PM
DarkShark's Avatar
Don't have a warranty on my car, I bought it used from an older lady. I found it online for about $135.00 which isn't to bad. I can install and replace this equipment myself.
Old Jan 17, 2005 | 05:26 PM
bryce804's Avatar
y don't you just ask tibby chick. she already stated she has three and im sure shell give you a better price then $135.00
Old Jan 17, 2005 | 06:02 PM
Casper's Avatar
You guys have to look into U-pull-it junkyards... There starting to throw 97-98 tibs in there (atleist here anyway, there are 2 in the yard I go to alot). This is the price right off their list:
Window Regulator (with motor) Cost: $15.90 Core:$2.00
Window Regulator(without motor) Cost: $7.40
Not that you shouldnt spend your money, but why spend $135 when you can pull it out of the car (Hey, you can find out how to put it IN this way, without breaking YOUR tib) for $8.
Old Jan 17, 2005 | 06:35 PM
DarkShark's Avatar
I've looked into pull it yourself junkyards and have had no luck. I'll keep looking because im not wanting to settle for $135. It's just the lowest price I have found for the time being.
Old Jan 17, 2005 | 07:12 PM
Casper's Avatar
You have to have a couple in your area. Check them like once every month or two. They cycle their cars on a schedule. I checked 4 different ones before I found one that has a good selection of imports.
Old Jan 18, 2005 | 06:04 AM
135? that seems a bit steep. I had a window replaced in a friends T bird for that much... and that was with labor at a glass shop.
Old Jan 25, 2005 | 10:00 AM
otverge's Avatar
Yeah, it's your cable... same thing happened to me. It rusted out from water getting in there and snapped. The crappy thing is, the motor in your regulator is probably fine... but you can't buy just the cable, they are attached as one piece. Doh.
Keep checking the junkyards, thats where I got mine.
Tom
Old Jan 25, 2005 | 03:50 PM
demon_fox's Avatar
Vehicle: 2000 hyundai tiburon
to prevent it happening again you might want to replace the seals on your window and doors. i used to see it alot when i worked in my shop before i came into the military. usually it didn't occur once we did that, you also want to find some weather proofing for you cables, sorry didnt mean to double post hit send beforre i was done
