top recorded horse power for a 2.0 beta engine?
Old Mar 6, 2002 | 01:44 AM
4CyLofFuRy's Avatar
hehe if only a supra engine would fit in the car.......
Old Mar 6, 2002 | 02:05 AM
aktivkontrol's Avatar
What exact mods would one recommend for a street '01 Tib at around 300-400hp?
Z?
Old Mar 6, 2002 | 02:36 AM
Decker's Avatar
got a easier and cheaper way, check out
http://www.darwinawards.com/darwin/darwin1995-04.html
Old Mar 6, 2002 | 02:37 AM
Veniston's Avatar
Yeah but none of that power would dyno at the wheels...
Old Mar 6, 2002 | 03:38 AM
Red's Avatar
Red
To get a Tiburon reliably to the 300+WHP mark, you're looking at about $10,000 worth of work not including labor.
The thing is, that work would be perfectly sufficient for 300WHP, as well as about 600WHP...
-Red-
Old Mar 6, 2002 | 01:56 PM
<div class='quotetop'>QUOTE </div><div class='quotemain'>Red:
Yeah, I think I'll probably draw the line around 325-350 for the street use. But if I'm at the track? I'm still considering strapping on a direct-port setup and spraying my way into the 500WHP area while at the strip.
Guess we'll see, huh?
-Red-</div>Red, when you get there, you better let me strap into the right-side seat one day. That would be the greates'.
Old Mar 6, 2002 | 04:43 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
red:
What if your on the race track, with racegas, nitrous, a zillion psi of boost, race slicks, and all the works, and you launch...
you wasted all your money just for this...
kinda makes you think, doesnt it?
Old Mar 7, 2002 | 12:35 AM
Red's Avatar
Red
Nope, not worried one bit.
If I spent $4000 on just a UFB turbo kit, I might be worried... Stock rods? Stock bearing clearances? Hyper-eutectic pistons? Push about 1.5bar of boost into that type of setup for very long at it will start to break down.
But I'm not doing that.
The engine is being severely over-built for my application. For nearly all of it, I've been following the build "recipe" that the Koreans use for their severe-duty engines. If they can crank 600+ wheel horsepower in an engine built the same way that I'm doing mine, then I'm not worried about 350WHP + 150 shot of nitrous.
And if it blows up?
Who cares? It's a project. Making an engine create 3x it's stock-rated horsepower comes with risks -- one of them is turning it into a grenade. Yeah it would suck, but I'd probably just rebuild it again.
But this motor, on 350WHP and nitrous? Nope, not worried one bit.
-Red-
Old Mar 7, 2002 | 02:40 PM
Jeebus Red! Who cares, it's a project?!
I think you need to funnel some of that new-job money my way homie!
Old Mar 7, 2002 | 04:57 PM
lantraluvr's Avatar
Red:
i thought the Ballistic kit is a-ok? why do you think that it wouldnt be strong enough? if i had a 2.0 and a ton of money i will buy his kit...
