Question..
Old Jan 19, 2005 | 08:36 AM
BuuGieWuuGie's Avatar
Default Question..
Ok. If i wanted to get the airram does it matter what tb i get? and does it matter what headers i use? also if i get this stuff. would i have to change anything like computer wise?
Old Jan 19, 2005 | 08:41 AM
JalemX's Avatar
not turbo get the 58mm
turbo = 65mm or higher i believe
donno about the headers
i think it's bolt on you don't need to do any ecu shiz except a reset.
Old Jan 19, 2005 | 08:49 AM
CyberShark's Avatar
OK using an Air Ram with N/A you can go anywhere from 58mm to 62mm..anything more then that and you'll loose power due to loss of air velocity.
If you go turbo with an AirRam you can go from 58mm to 70mm. 70mm will only work if you enlarge the AirRam opening to fit. I think the AirRam come with a 67 to 68mm opening.
Old Jan 19, 2005 | 11:47 AM
TiburonWao's Avatar
Ok... www.Kspec.com recomend that when using the AirRam, you should use a BBTB.... You will feel more HP gain
Old Jan 19, 2005 | 03:03 PM
Just so everyone knows...
Next GB is gonna be a 2fer by Kspec.com
1. Beta 2 Valve Covers. CVVT available also.
2. Airrams.
Old Jan 19, 2005 | 08:32 PM
Alex01tib's Avatar
sweet...you probably dont know prices yet do ya redz?
Old Jan 19, 2005 | 10:58 PM
Actually, I do.
Old Jan 20, 2005 | 12:43 AM
01tibby341's Avatar
^ So if im understanding this right there will be a GB on the Airram?
If so im definatlly in on it. What about the Rside BBTB? That would be nice if we could get a GB on thoes to, It would go along great w/ the airram.
Old Jan 20, 2005 | 07:34 AM
Yes, the Airram is going on GB again.
No, the Rside adjustable is no longer available, but you can get any of the other BBTB's we offer.
