Header question....
Old Jan 18, 2005 | 12:34 AM
Dmatrix's Avatar
Default Header question....
Ok i was gonna pick up the ssa header/exhaust combo from ebay but then i was wonderin will that header work with a turbo? Thinkin about goin turbo in the near future but gotta learn all about it first.
*Moderater Edit*
Hey man, you already saw the auto warning for using Obscenities... just editing it out for you.
Mad-Machine
Old Jan 18, 2005 | 12:36 AM
a_gut's Avatar
Headers + turbo are not compatible. You need a turbo manifold for a turbo, which would replace those headers. The exhaust should work though.
Old Jan 18, 2005 | 12:42 AM
Alex01tib's Avatar
yah if you got headers then got a turbo it would be a waste...take the money you were gonna drop on the headers and get a BBTB or something else that you will be able to use on N/A and under Boost.
Old Jan 18, 2005 | 02:05 AM
Mister_Sinister's Avatar
Actually, a BBTB wouldn't necessarilly be a better buy. While a 60mm TB is good for NA, a 70mm TB would be better for a turbo. If you really wanna get a good upgrade that you can use on a NA setup and a FI setup, get the AirRam IM. Of course a Haltech E6X would be awesome too, even if it is a bit overkill.
Old Jan 18, 2005 | 06:54 AM
Alex01tib's Avatar
yah but i figured he wouldnt have 599 to drop on an air ram (kspec). and i said the BBTB because it was less than the Air ram but i agree. i was just saying to get something he could use on both with the money. maybe underdrive pulley, plugs, or just straight saving for the turbo
Old Jan 18, 2005 | 07:54 AM
CyberShark's Avatar
DMatrix if you are getting a turbo soon. You would be better off with an AirRam or something else you can use with the turbo.
Old Jan 19, 2005 | 12:37 AM
Dmatrix's Avatar
how much does one of those kspec underdrive pulleys help?
also does anyone have one of those set ups yet? With the ssa header and the catback. I just purchased mine so will find out how good it is. I figured i wont get my turbo for a while so why not.
Old Jan 19, 2005 | 05:52 AM
hamhead's Avatar
Underdrive pulleys will help that you can feel only in first gear. They don't really help upper gears as much. If you want to get something before the turbo, get a better clutch (if you have a manual). Or at least put the little money you have aside for one.
Old Jan 20, 2005 | 02:39 PM
CyberShark's Avatar
<div class='quotetop'>QUOTE (Dmatrix)</div><div class='quotemain'>how much does one of those kspec underdrive pulleys help?
also does anyone have one of those set ups yet? With the ssa header and the catback. I just purchased mine so will find out how good it is. I figured i wont get my turbo for a while so why not.</div>
I noticed a difference with my three piece pully set...my underdrive pully weighs less then a pound compared to the stock 4lb one..it may not seem like much but it makes a difference any time you lighten up the wieght of rotational mass.
Old Jan 20, 2005 | 07:01 PM
Double_A's Avatar
Yea dude, im goin turbo real soon and i thought i might a while ago so opted for an unorthodox underdrive pulley. I can def. feel more power in the lower r.p.m.s in first and second. And the best part about it was that i picked a used one up for $70.00.
