Problems With My Hid
Well I have a set of HID for my lowbeams. Since I have the KDM Glass headlights i'm using H1's.
Anyways, ive had them for a while now and never had any problems. But now I have a problem with both of them coming on when I turn the lever. My left side turns on just fine but the right side doesnt.
It takes a couple of turns (sometimes a lot) in order for the passenger side light to come on. If anyone else has them you know that turning them off and on will eventually harm the bulb. So the driver side one is gonna burn out soon unless i fix this problem.
Could it be the relay? I dont think it is but what else could it be?
^^^ i have the same ground for both. well the same area on each side. I dont think they got wet. Should i take it apart?
<div class='quotetop'>QUOTE (OdessitPashka @ Sep 21 2005, 12:01 AM)</div><div class='quotemain'>It could be any part of the HID kit. Ignitor could be going out or something wrong with the ballast. Did either one get wet by any chance?
damn the ignitor or the ballast? that sucks. i paid like 480 for that kit a few years back. i know its not the bulb because its got the better color. like it hasnt been used that much as the driver side. damn.
Vehicle: 2004 Acura TL
First off, do you mean the High/Low (Daytime) beam or just the normal headlights you have to turn on with the headlight switch?
If it's the headlights I dunno, OP has a pretty good reason for it methinks. Otherwise it could just be old age.
^^^i dont think its the bulb. it has more life than the driver side im sure.
<div class='quotetop'>QUOTE (silvertibbs @ Sep 21 2005, 03:39 PM)</div><div class='quotemain'>First off, do you mean the High/Low (Daytime) beam or just the normal headlights you have to turn on with the headlight switch?
headlights with the stock headlight switch.
<div class='quotetop'>QUOTE (tibby01 @ Sep 21 2005, 04:29 PM)</div><div class='quotemain'>im thinking its the igniter as well, but check to make sure all connections are tight and free of corrosion.
ill check it all again tommorrow. hope its not the igniter. money money money.
its a philips kit. the bulbs are suppossed to be ultinon but im not positive. it sayd philips on the ballast but not on the bulbs.
