over heating
Old Sep 15, 2004 | 12:49 PM
97supalude's Avatar
Default Re: NOS!!!
hey guys. my gfs 2000 tib has a problem. the temp is fine when she is driving normally, but when she pulls up to a light with the a/c on, the temp jumps all the way up. then when she starts driving again, it goes back down. what could this be? and what should i be checking?
Old Sep 15, 2004 | 01:49 PM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
Default Re: Fable
Sounds like a classic thermostat problem. Try getting it replaced.
Old Sep 15, 2004 | 03:47 PM
iamcyclopseatme's Avatar
Default Re: no idea what the problem is?
<span style="font-size:36pt;line-height:100%"><span style="color:red">*SENSELESS POST DELETED BY ADMIN*</span></span>
Old Sep 15, 2004 | 05:15 PM
Default Re: aftermarket parts for sale
Thermostat problem most def mang. Get that sucka replaced or just completely take it out for now.
Old Sep 15, 2004 | 05:52 PM
97supalude's Avatar
Default Re: NOS!!! (NITROUS - NOS IS A BRAND NAME!!!)
ok thanks. so thats usually the problem? any ideas on how much a new one costs, and how difficult is it to replace it myself?
Old Sep 15, 2004 | 06:02 PM
Default Re: FS: lots of stuff
I about guarantee it's the problem.
The thermostat has a little pellet in it that reacts to heat. When it gets hot it smushes and lets the valve open and hot fluid goes thru to the radiator, keeping your car cool. If the thermostat gets damaged or corroded shut, it will not open letting it thru. Then when you sit at a light, it heats up because there is no air going thru the engine.
Run outside and check the antifreeze mang. Tell me if it's at the right level and what color it is. Also, if the engine is cool, pop off the radiator cap and look in there too. Tell me the same.
Thermostats are easy to replace. 2 or 3 bolts, remove a hose, take it out, put the new one in with some sealant, put everything back and refill your coolant. Remember Antifreeze is also COOLANT.
Prolly cost under $20.
Old Sep 15, 2004 | 07:34 PM
Dweet's Avatar
Default Re: Kspec GT/Racing Header Group Buy *GT 8/10 R 10/10*
Old Sep 15, 2004 | 08:37 PM
Default Re: Wheel Spacer?
Another thing to check... your fans. Do they come on when the car gets hot and do they come on when the air is on? A good way to check if it is your thermostat.. when the car is at operating tempeture.. feel the radiator.. it should have a nice gradiant to the temp.. going from hot at the top to cooler at the bottom.
Old Sep 16, 2004 | 03:14 AM
Tiburonmoo's Avatar
Default Re: FS: Custom COLORED Shift Boots!
<div class='quotetop'>QUOTE </div><div class='quotemain'>when the car is at operating tempeture.. feel the radiator..</div>
Did you really just say that????? 8O
Old Sep 16, 2004 | 05:55 AM
Default Re: Pyle of sound or Pyle of crap?
yes, I really did say that. I am not talking about sticking your hand in the coolant, but simply touching the fins to see which are hot and which are not. Unless you leave your hand there for more than a few seconds, you are not going to get burned.
