OBD II Reader
Old Jan 12, 2005 | 06:31 PM
About what?
Old Jan 13, 2005 | 10:53 AM
bryce804's Avatar
<div class='quotetop'>QUOTE (REDZMAN)</div><div class='quotemain'>^^^
About what?</div>
Old Jan 13, 2005 | 11:19 AM
rallyman's Avatar
<div class='quotetop'>QUOTE (REDZMAN)</div><div class='quotemain'>I just checked their site and am IMPRESSED.
That thing looks amazing.
Ever use the Dyno feature mang?
Did anyone see this?
Can I customize?</div>
I never did try the Dyno feature. But the scan tool and software worked great and was very easy to use. I ended up getting rid of my laptop and the scan tool though and bought the CarChip E/X. It is very impressive. If all you need to do is check codes and clear the CEL they have a tool for $79, I think.
Old Jan 13, 2005 | 04:47 PM
Doode, tell us about the CarChipFX.
Old Jan 14, 2005 | 11:55 AM
rallyman's Avatar
Trying to but having a problem posting.
I guess the post was too long. Cut it down in size and seems to work now. See below.
Old Jan 14, 2005 | 11:56 AM
rallyman's Avatar
OK, the CarChip E/X is a tiny device that plugs into the OBDII port on the car. It isn't much bigger than the port itself and sticks out about 3/4" when installed. Everytime you drive the car it logs the time and date the trip was started and stopped, the distance travelled, the average speed, the maximum speed, the time driven in different speed windows (user definable), number of hard and extreme accelerations and braking. It logs any error codes as they happen and alllows you to reset the CEL. It also allows you to select up to four different sensor readings to log from a list of about two dozen. Things like coolant temp, intake air temp, O2 voltage, etc. Anything the car has a sensor for, basically.
