OBD II Reader
Old Jan 12, 2005 | 12:41 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Default OBD II Reader
Any of you guys have an OBD II bought of ebay? If so which one?
Im looking into buying one but I visted a shop near here and they are charging 250$. They are the only place that carries them
any links will help ;P
Old Jan 12, 2005 | 12:44 PM
UltraTibby's Avatar
If you are looking for one, try to find one that will also give you all of the voltage specs as well as read pending codes. The one I have does not have that and I and looking to buy one that does. Just buying one like that from the start will save you a few bucks.
Old Jan 12, 2005 | 12:48 PM
spiceflow's Avatar
The best one I have seen is Autotap, which costs $199. You will need a laptop or PDA, however. If you are just looking to get the number codes, then I think any of the cheap ones on ebay would do.
http://www.autotap.com/autotap_for_windows.html
Old Jan 12, 2005 | 01:00 PM
tanc's Avatar
the codes is basicly all I need right? With the codes I can check why im reading the error and solve the problem..
Correct me if I'm wrong, I don't know much about OBD readers
rallyman's Avatar
Check www.digimoto.com . I have used their scantool and software and it is great. I recently purchased the CarChip E/X through them and love it. It is tiny and you just plug it into the OBDII port and then download the info onto your desktop PC. It will log up to 300 hours of driving and you can specify up to four different sensors/readings you want logged. If you want to see the information in realtime you'll want to stick with the scantool and your laptop but I like the CarChip because it is completely out of sight and you can just leave it plugged in for days at a time and then download the info whenever you want.
Digimoto sells their scantool packages on eBay as well as their web site and they can be purchased for around $100. I highly recommend them.
Old Jan 12, 2005 | 01:08 PM
UltraTibby's Avatar
<div class='quotetop'>QUOTE (tanc)</div><div class='quotemain'>the codes is basicly all I need right? With the codes I can check why im reading the error and solve the problem..
Correct me if I'm wrong, I don't know much about OBD readers</div>
You are correct. If you dont plan on needing any of the voltage information then a regular reader should work fine. It will allow you to see and reset what your code is and based on that code you can then troubleshoot the issue.
Old Jan 12, 2005 | 02:04 PM
<div class='quotetop'>QUOTE (rallyman)</div><div class='quotemain'>Check www.digimoto.com . I have used their scantool and software and it is great. I recently purchased the CarChip E/X through them and love it. It is tiny and you just plug it into the OBDII port and then download the info onto your desktop PC. It will log up to 300 hours of driving and you can specify up to four different sensors/readings you want logged. If you want to see the information in realtime you'll want to stick with the scantool and your laptop but I like the CarChip because it is completely out of sight and you can just leave it plugged in for days at a time and then download the info whenever you want.
Digimoto sells their scantool packages on eBay as well as their web site and they can be purchased for around $100. I highly recommend them.</div>
I just checked their site and am IMPRESSED.
That thing looks amazing.
Ever use the Dyno feature mang?
Did anyone see this?
Can I customize?
<div class='quotetop'>QUOTE </div><div class='quotemain'>We do offer customizations to our distributors. If you run a car club or you are looking to distribute our software with your name and logo on it, we are always willing to work with you on this type of project (free of charge). Everything within the application can be customized down to the colors on the charts. To receive more information on this please contact us at sales@digimoto.com.</div>
Hmm... Wonder if we could do a GB.
Old Jan 12, 2005 | 02:37 PM
tanc's Avatar
It looks awsome
Old Jan 12, 2005 | 05:16 PM
Cuda-Turbo's Avatar
Wow I would get in on a GB that thing rocks!
Old Jan 12, 2005 | 05:36 PM
bryce804's Avatar
i don't know...
