No Lights
Check to see if you're getting power to your leads. Could be Fuses, relays or even the switch on the steering column. But if I recall the lights are split left and right. Check the fusebox under the hood, to me, it sounds like that could be your source.
if the fuses are allright you may want to check the main ground to see if it has come loose. it is located behind the bumper ,on the passenger side, just to the right of the radiator. not too hard to find since it is the only wire in that area that is bolted right to the rad support.
There is a Sticky in this forum for fuse information: http://www.rdtiburon.com/index.php?showtopic=15789
I don't think it's going to help you much though. Give us as much information as possible.
1. Do tail lights work when the headlights are in the ON position?
2. What about brake lights when the pedal is pressed?
3. Does the radio work? If you have a sunroof, does it work?
Some of these are tied to similar fuses. It'll help us narrow it down. For fogs, low, and high beams to not work is really weird. I'm not sure what would cause that.
<div class='quotetop'>QUOTE (UrS0NvS @ Dec 28 2009, 12:08 AM) <{POST_SNAPBACK}></div><div class='quotemain'>if the fuses are allright you may want to check the main ground to see if it has come loose. it is located behind the bumper ,on the passenger side, just to the right of the radiator. not too hard to find since it is the only wire in that area that is bolted right to the rad support.</div>
That's what I thought the only problem could be if the fuse was good.....
Until one day I helped someone with their headlamps and found out it was two bad bulbs. LOL!
