NEW PROJECT!!
Old Feb 19, 2015 | 06:55 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
Yeah stick around, could be a fun ride! I quite possibly will have a new intake manifold option for the V6 guys..
Old Apr 8, 2015 | 07:32 AM
03tibe85's Avatar
She's alive and slurping E85!! FYI..swapping in XG350 3.5L /Sonata 2.4L 290cc injectors with the stock fuel pump on the V6 engine = STFTrims in the +/- 1-2% range.
Now next issue is tracing down what I'm sure is either a jack shaft or wheel bearing issue..
Don't mind the pep boys stickers on firewall..those are already removed..
File Type: jpg
File Type: jpg
Old Apr 8, 2015 | 11:20 AM
tibbytib's Avatar
Damn dude! Can't wait to see this on the road! So...did you get the "garage" upgrades approved yet by higher managment? You know you wanna keep these babies you keep resurrecting from the grave!
Old Apr 9, 2015 | 10:03 AM
03tibe85's Avatar
Nope I did not.. So either Celica or Tib has to go. You can pretty much guess which one is going though..
Old Apr 28, 2015 | 08:52 AM
03tibe85's Avatar
Just a slight update with no pics. Tib is on the road running E85. I gotta say this V6 engine LOVES E85. Even for a 150k engine it feels very strong. The OE ECU seems to be perfectly happy running E85 with the 290cc injectors I have in there. Trims are +/- 2% right now.
I will be installing a piggyback ECU in the future to add some ignition timing to the mix to really wake things up as well as get ready for um....other things..
Old Apr 28, 2015 | 12:40 PM
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
You are running E85 with just 290cc and no piggyback? Interesting.
Old Apr 28, 2015 | 12:49 PM
tibbytib's Avatar
Other things......
Old Apr 28, 2015 | 12:55 PM
JonGTR's Avatar
Nice. Quite a coincidence that those injectors match up so nicely.
What piggyback are you going with? I still have the Perfect Power PRS-4 that I'd let go dirt cheap. I ran it as a piggyback.
Old Apr 28, 2015 | 01:44 PM
03tibe85's Avatar
Yup, its all about lambda baby! If you can pair a set of injectors that are the right size larger to compensate for the added fuel needed for E85 the OE ECU takes care of the rest. As far as it knows its running premium gasoline on stock injectors, except this 'gas' cost 1.60 a gallon..and is 106 octane..
I'm going to run a new product from Perfect Power called the SMTFX which installs between the injector leads to control the injectors directly and has a nifty auto tune feature with fuel trims and the works.
Old Apr 28, 2015 | 06:23 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
$1.60/gal ?!?!?!?! It's $2.79 here in Vegas (about the same price as regular gas). Thanks Commifornia!
