Need help: car is running weird
Old Oct 21, 2004 | 10:19 AM
wattsup4800's Avatar
Default Re: Worst rice mod you've done to your car!
Ok so im driving on the expressway to work @ 70 mph probally .25 throttle
and all of a sudden my car bucks and my rpms suddenly begin to fall
now im @60 mph i then give car full throttle nothing for about 2 seconds
then car regains itself
less than 5 min later
once again around 65-70mph less than .25 throttle
it happens again this time the rpms slowly drop along with my mph
60, 55, 50, .... all the way down to 40mph
during this i did the same thing floored it and nothing
so i downshifted to fourth nothing
third nothing .... until final regained life again
need some help
Old Oct 21, 2004 | 10:31 AM
cjme2002's Avatar
Default Re: As promised... WORK WORNING, HIDE YOUR CHILDREN!
it kinda sounds like the same sort of thing m y car was going through. i took it to the shop and it threw an error code saying that my throttle was at 84% but my RPMS only measured 700 and my car wouldn't go faster...it just sat there for a bit before it regained itself
they said my throttle plate was dirty as hell....maybe go get that cleaned. here's the thread to what my car was doing:
http://www.rdtiburon.com/index.php?name=Fo...viewtopic&t=501
Old Oct 21, 2004 | 10:35 AM
a_gut's Avatar
Default More questions
I has something similar happen to me, it ended up being a loose connection somewhere in the engine bay.
Old Oct 21, 2004 | 10:36 AM
Default Re: Need help: car is running weird
what type of connection
Old Oct 21, 2004 | 12:18 PM
Dweet's Avatar
Default Re: help me fix the computer.
could be alot of things, but sounds like you are running out of fuel for one reason or another.... either by somet type of blockage, bad pump, or a sensor vital to performing fuel delivery properly isnt functioning correctly.
Or it could be a dead/dying spark plug because that happened in my elantra.
Give us some more info on your car like mileage, maintenance performed and other stuff done recently to the car. and we might be of further assistance smile.gif
Old Oct 21, 2004 | 12:28 PM
Default Re: 04 CVVT Turboed - Speed Factor kit
just hit 108k
have not done anything to the car at all since IM was installed
I was running lean at that point
i changed the fuel filter last year
i changed the pump last year and there was no change so i put the old one back in
just picked up my MSD igntion system with blaster coil
could this possibly help
Old Oct 21, 2004 | 12:31 PM
Dweet's Avatar
when was the last time you gave it a tune up?
Old Oct 21, 2004 | 12:32 PM
changed plugs and wires probally 3 months ago
Old Oct 21, 2004 | 12:34 PM
Dweet's Avatar
check the gapping of the plugs when you put them in? also run some fuel injector cleaner though it...
If you get a CEL check it out and see what it is.
Old Oct 21, 2004 | 12:37 PM
ive been putting fuel injector cleanor in prob once a month
any other ideas DWEET or anyone else
