Might As Well...
Old Oct 4, 2005 | 08:43 PM
matmag89's Avatar
Well, Im pulling my motor, and I was wondering, I might as well buy some stuff to beef up HP a tiny bit. Dont really want to go turbo (I want a this to be my winter car). So I was thinking:
1- 1.8L Cam
2- 65mm BBTB
3- Airram intake Manifold
Does that sound good enough?
If I get the Cam should I get the Cam sprocket too?
Old Oct 4, 2005 | 11:34 PM
mb1604's Avatar
good list, what do you have now? if you get a sprocket youll have to tune it. just putting one on wont do anything for you
Old Oct 4, 2005 | 11:37 PM
OdessitPashka's Avatar
If you don't plan on putting out lots of power, you can get away with just porting and polishing your stock manifold smile.gif
Old Oct 5, 2005 | 09:41 AM
<div class='quotetop'>QUOTE (matmag89 @ Oct 4 2005, 10:43 PM)</div><div class='quotemain'>Well, Im pulling my motor, and I was wondering, I might as well buy some stuff to beef up HP a tiny bit. Dont really want to go turbo (I want a this to be my winter car).
If you are pulling your engine.. and this assumes you have a stick. I might suggest a Fidenza lightened flywheel. To remove your old flywheel and have it resurfaced would cost you half of what it would cost to put a lightened flywheel in and gain back some of the HP the engine uses to drive itself.
Beware though, first time you try and drive with a lightened flywheel.. you ARE going to stall.
Old Oct 5, 2005 | 09:45 AM
'treezy's Avatar
Haha, Mad_machine's last line = S00oooo True.
Old Oct 5, 2005 | 06:12 PM
<div class='quotetop'>QUOTE (Mad-Machine @ Oct 5 2005, 10:41 AM)</div><div class='quotemain'>Beware though, first time you try and drive with a lightened flywheel.. you ARE going to stall.
I didn't stall when I drive a car with stage 3 clutch and lighter flywheel for the 1st time smile.gif I'm that goood smile.gif
Old Oct 5, 2005 | 06:55 PM
matmag89's Avatar
<div class='quotetop'>QUOTE (mb1604 @ Oct 5 2005, 05:34 AM)</div><div class='quotemain'>good list, what do you have now? if you get a sprocket youll have to tune it. just putting one on wont do anything for you
I got SSAC Header, Motoria, Injen CAI, OBX Overdrive and Underdrive Pulleys, and a Fidanza Cam Gear in my trunk.
Old Oct 5, 2005 | 07:41 PM
mb1604's Avatar
id say get a 1.8l cam, bbtb and maybe afc
