Well, Im pulling my motor, and I was wondering, I might as well buy some stuff to beef up HP a tiny bit. Dont really want to go turbo (I want a this to be my winter car). So I was thinking:
1- 1.8L Cam 2- 65mm BBTB 3- Airram intake Manifold Does that sound good enough? If I get the Cam should I get the Cam sprocket too? |
good list, what do you have now? if you get a sprocket youll have to tune it. just putting one on wont do anything for you
If you don't plan on putting out lots of power, you can get away with just porting and polishing your stock manifold smile.gif
<div class='quotetop'>QUOTE (matmag89 @ Oct 4 2005, 10:43 PM)</div><div class='quotemain'>Well, Im pulling my motor, and I was wondering, I might as well buy some stuff to beef up HP a tiny bit. Dont really want to go turbo (I want a this to be my winter car).
<div align='right'><{POST_SNAPBACK}></div></div> If you are pulling your engine.. and this assumes you have a stick. I might suggest a Fidenza lightened flywheel. To remove your old flywheel and have it resurfaced would cost you half of what it would cost to put a lightened flywheel in and gain back some of the HP the engine uses to drive itself. Beware though, first time you try and drive with a lightened flywheel.. you ARE going to stall. |
Haha, Mad_machine's last line = S00oooo True.
<div class='quotetop'>QUOTE (Mad-Machine @ Oct 5 2005, 10:41 AM)</div><div class='quotemain'>Beware though, first time you try and drive with a lightened flywheel.. you ARE going to stall.
<div align='right'><{POST_SNAPBACK}></div></div> I didn't stall when I drive a car with stage 3 clutch and lighter flywheel for the 1st time smile.gif I'm that goood smile.gif Flywheel would be a good idea though smile.gif |
<div class='quotetop'>QUOTE (mb1604 @ Oct 5 2005, 05:34 AM)</div><div class='quotemain'>good list, what do you have now? if you get a sprocket youll have to tune it. just putting one on wont do anything for you
<div align='right'><{POST_SNAPBACK}></div></div> I got SSAC Header, Motoria, Injen CAI, OBX Overdrive and Underdrive Pulleys, and a Fidanza Cam Gear in my trunk. |
id say get a 1.8l cam, bbtb and maybe afc
