Hot Inzama System
Old Oct 3, 2004 | 04:55 PM
CyberShark's Avatar
Default Re: Turbo or no?
Hey guys, I've read the last couple of issues of Import Tuner. I've noticed in these issues, they've been testing the Direct Power System on their cars. I was wondering if the Hot Inzama System is similar to the Direct Power System or if there are any differences...thanks
Old Oct 4, 2004 | 05:20 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Installing an Autometer Tachometer with Shift Light
Never heard of it. What does it do? I haven't been able to find anything.
Old Oct 4, 2004 | 07:28 AM
GreatLakesTib's Avatar
From what I have seen of both systems they appear to do the same things.....however there is not much info on Hot Inzama System on k-specs website.....and I also have to assume people are going to start asking about the gains of such a system.....however untill someone buys and dynos one the gains are to be seen. From what I have read of other similar systems the gains will vary with what else you have done to your car .
Old Oct 4, 2004 | 07:39 AM
CyberShark's Avatar
Default Re: What gas do you use and what miliage do you get with it?
<div class='quotetop'>QUOTE (silvertibbs)</div><div class='quotemain'>Never heard of it. What does it do? I haven't been able to find anything.</div>
I don't know exactly how those little boxes work but I know that it is supposed have something to do with the battery..I guess it's supposed to increase voltage by replacing the lead cables.
On the Direct power system, Import Tuner was able to get 1hp and .5lb torque on car they tested two months(It was a Toyota). On this months car, it did not show any benifits. I forgot which cars they tested them on exactly, but they stated they had seen as much as 16horse improvement on a turbo application. The Direct Power System cost around $300 and I noticed the Inzama was about $100 cheaper. I would still like to know if there are any differences.
Old Oct 4, 2004 | 09:59 AM
Default Re: Fuel Management
That would be interesting to see. It sounds like it's something like a ground wire kit, or at least the same idea. I would think that there would be no difference, but cause the Direct Power kit was in a mag they might be able to get more $$$. It prolly has something to do with better wires (larger) or stronger fuses or something like that.
Old Oct 4, 2004 | 10:08 AM
Dweet's Avatar
sorry but these are about as useless as groundwires
Old Oct 4, 2004 | 11:12 AM
CyberShark's Avatar
Default Re: *Exhaust Listings* Currently Available...
Dweet, do you have any idea what those little boxes do?
Old Oct 4, 2004 | 11:42 AM
tibwrcsbj's Avatar
Default Re: faster car
voltage stabilization.
In short, they are supposed to smooth out the electron flow....ie fewer spikes.....spikes that can cuase damage to electrical systems.
While dweet was half right, they really wont show much, if any PERFORMANCE gains, they do help out in other areas, as im sure you've seen stated somewhere, like headlights being brighter.....
the 16whp for that turbo app......I am guessing (you wont here that much from me, but then you guys should already know that) that the gain was because of more ACCURATE readings from sensors. That gain would also highly depend on what kind of boost controls were on the car.
Old Oct 4, 2004 | 12:21 PM
CyberShark's Avatar
Great answer man...thanks for the input.
Old Oct 4, 2004 | 12:27 PM
tibwrcsbj's Avatar
Default Re: stupid newbie question here
wink.gif NP mang.
there was also a huge debate about them a few months ago on HP. You know, the typical Autobot telling someone else they were wrong kind of debate....hehe.
