Glass packed muffler question
Old Oct 20, 2004 | 12:01 AM
nate704's Avatar
Default Re: Boostin a 97 tibbie
I bought a glass packed and louvered core muffle, which goes between the cat and main rear muffler.
Anyone knows the direction of the muffler?
It looks like this when you see from one side.
The other side loooks this.
Which direction is correct?
Please let me know~!
Thank you
Old Oct 20, 2004 | 12:12 AM
OdessitPashka's Avatar
the way it is now, is the way it should be, exhaust gases will enter to the side where you cant see the holes.
Old Oct 20, 2004 | 06:24 AM
Default Re: hp stock rods
of course you realise that you bought the worst glasspack for exhaust flow, right? IF you look carefully down the length of the exhaust path.. that 2 1/2 or 2/14 inch tube is actually a LOT smaller thanks to the louvers. Also, they tend to swirl the exhaust and create eddies... makes for LOTS of backpressure.
Old Oct 20, 2004 | 11:18 AM
nate704's Avatar
Default Re: Need assistance with my SAFCII
<div class='quotetop'>QUOTE (OdessitPashka)</div><div class='quotemain'>the way it is now, is the way it should be, exhaust gases will enter to the side where you cant see the holes.</div>
My muffler shop installed the muffler backwards!!!
exhaust gasese enters to the side where you CAN see the holes!!!
Should I go to the shop and tell them to fix it? Or Can I just leave it like that?
Please tell me what to do~!!
Old Oct 20, 2004 | 12:03 PM
Default Re: nitrous question
you should take that junk resonator off and get yourself a thrush turbo
uses a perforated core instead of louvers
costs about 25 or so
Old Oct 20, 2004 | 12:45 PM
Default Re: More Exhaust Help
<div class='quotetop'>QUOTE (faithofadragon)</div><div class='quotemain'>you should take that junk resonator off and get yourself a thrush turbo
costs about 25 or so</div>
do what he said!
Old Oct 20, 2004 | 05:06 PM
Default Re: Vibration while in neutral
ayup.. perforated is the better glasspack.. nothing sticks out into the exhaust flow
Old Oct 22, 2004 | 07:12 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: header cover
Are these glass packs better performance wise or does it just deaden noise better??
Old Oct 22, 2004 | 07:22 AM
Default Re: Glass packed muffler question
it does both
exhaust flows right through with nothing to catch it and the sound waves will be absorbed into the perforations
Old Oct 22, 2004 | 11:34 AM
Default Re: Radiator Hose
Nice, thanks.
