Gauges, How many?
Old Dec 9, 2004 | 07:55 PM
01tibby341's Avatar
Default Re: the official RD REDZ ROAST!!!!!!!!
just wondering how many gauges are available for a turbo set up? I know there is air/fuel ratio, boost, water temp, what else? i've look at my car and have found enough spots for 7 gauges. Are there that many gauges available and are they necessary or just dumb to have that many?
Old Dec 9, 2004 | 08:28 PM
TiburonWao's Avatar
Default Re: 97 & 99 Tiburon part out
Water Gauge???? mmmmmm not sure about that.,...
But... you can get the Oil Pressure Gauge.... and EGT Gauge...
Old Dec 9, 2004 | 08:53 PM
2bits's Avatar
Default Re: Pictures of the tiburon
I dont think 7 is really nesscary, but like 3-4 should do u fine...
Old Dec 9, 2004 | 09:12 PM
oil pressure
water temp.
egt
A/F
Voltage
Boost
those are the only ones i can think of that are necessary
Old Dec 9, 2004 | 09:42 PM
a_gut's Avatar
Old Dec 10, 2004 | 04:51 AM
TiburonWao's Avatar
Default Re: :( My Tib *Edit 12/8: all better - new pics*
<div class='quotetop'>QUOTE (a_gut)</div><div class='quotemain'>Don't forget IAT gauge laugh.gif</div>
I get los in this.... what is IAT???
Why the Water Temperature??? The Tiby has this sensor already???? Unless you got a Turbo with Water/Oil Cooling.....
Old Dec 10, 2004 | 05:07 AM
tibwrcsbj's Avatar
Default Re: Gauges, How many?
IAT = Intake Air Temp
Old Dec 10, 2004 | 06:18 AM
Default Re: Guess the lyrics
Never heard of that one... I HAVE heard of intercooler tempeture gages.. There is an aftermarket one for the porsche turbo that with a two position switch, can tell you the air temp before AND after the intercooler.
Old Dec 10, 2004 | 02:07 PM
<div class='quotetop'>QUOTE (TiburonWao)</div><div class='quotemain'><div class='quotetop'>QUOTE (a_gut)</div><div class='quotemain'>Don't forget IAT gauge laugh.gif</div>
Why the Water Temperature??? The Tiby has this sensor already???? Unless you got a Turbo with Water/Oil Cooling.....</div>
have you ever seen your stock water temp gauge idle at any other spot besides halfway and zero?
the thing only has like 3 different ranges, which it calculates to be low, medium, or high. not accurate at all.
Old Dec 10, 2004 | 02:41 PM
TiburonWao's Avatar
Default Re: RDTiburon Decals!
Ok.. good point......
But I really think that the three best gauge are Oil Temperature, Boost and EGT (or Air/Fuel)
