Ecu Tuning Program
Does anyone knows a program for ECU tuning for Hyundai???
I found severals programs, but can't read me the .bin file of my ECU.... and the one that I has is in Hexagecimal...
thanks.....
thanks.....
What ECU are you using? IIRC, you were using an ECU from a GK, right? What do you want to tune on the ECU?
In any case, the firmware used in korean tibs should be very different from what we got here... meaning that I probably wouldn't be able to do anything with it 02.gif But if you already have the .bin file, send it to me (along with info about your ECU, ie, model from which it's from, year and location in the world) and I'll see if I can get something out of it.
Thanks Agarwal...
As soon as I get into my home I will PM you.... My ECU is Siemens 2row Korean... need to advance the timing and lower the fuel at low RPM...
My OEM ECU is sit on my closet.... beside my injectors, fuel pump, map sensor, Intake CAM, and other stuff...
I will get more info for you later.. thanks....
