Dry filter versus oiled
Old Nov 4, 2010 | 08:11 AM
yellowtib's Avatar
Vehicle: 2000 Yellow Tib
Default Dry filter versus oiled
I am debating whether to get a K&N or an AEM filter since its time for a new one. I spoke with a couple of friends and they said that they used to use a K&N but switched to a dry filter because after a while, they opened their throttle body and said it was BLACK. They cleaned it and switched to a dry filter and that problem never happened again. Anyone else that uses an oiled filter looked at their throttle body lately? I know that they perform better than a dry filter, but at what cost? Any input?
Old Nov 4, 2010 | 08:56 AM
oh no you di-unt! I believe you have just opened the flood gates to rekindle a recent debate.
Here are a few off-topic posts we removed from another discussion. I've closed it to prevent rehasing old discussions.
https://www.hyundaiaftermarket.org/f...-sensors-mafs/
Old Nov 4, 2010 | 01:00 PM
I have had a K&N for at least 100k miles and the throttle plate just looks like old brass.
Old Nov 16, 2010 | 07:15 AM
daytonmvp23's Avatar
lol.....I won't get back on that debate but I will ask has anyone actually done a flow test comparing the dry flo to oiled? Just curios. Not debating one or the other....just curios. and if so post the results. I will ask the OP are you making this a cold air intake away from the engin or leaving it in the engine compartment? If you are leaving it in the engine compartment you are better off getting a high performance filter for the filter box then a cone filter. And yes there are a couple choices out between dry and wet that are hi performance as well.
Old Nov 16, 2010 | 01:25 PM
It will flow whatever the engine needs. The differential pressure will be the only difference.
Old Nov 17, 2010 | 08:09 AM
Yes I forget that symantics are important in a technical forum. Thus I repeat has anyone done an independent Dp test for the two? AEM says DryFlow is better K&N says Oiled is better. I am going on a limb here and saying that for most people the 20+shipping Ebay intake kit is as good as any one really ever needs unless you plan on making it an insanely powerful project.
Old Nov 17, 2010 | 09:00 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
I got a dry HKS Mushroom Filter, works great.
