Colt camshafts my RD tib
Old Mar 26, 2011 | 02:44 PM
  #21
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
You should be fine to use the valvetrain you got now, unless you're going with some crazy regrind.
Old Mar 31, 2011 | 12:55 AM
  #22
Sonique's Avatar
Vehicle: Hyundai Tiburon RD
Originally Posted by darkspectre614
.. unless you're going with some crazy regrind.
Don't know the profile yet.. but we decided to max the regrined to what's possible with hydraulic lifters and lash caps!
Old Mar 31, 2011 | 11:54 AM
  #23
That will be determined by a fancy computer. For a rule of thumb: if you start getting valve float, you went too big on the cam.
Old Mar 31, 2011 | 02:59 PM
  #24
Sonique's Avatar
Yeah, luckily i'm not the one that does the calculations : )
Old Apr 11, 2011 | 06:34 AM
  #25
Sonique's Avatar
So, they have decided what profile to grind now.. It will be
275 degrees duration
10.1mm lift
Old Apr 11, 2011 | 12:13 PM
  #26
You will be glad to run the Megasquirt with a profile like that. The stock computer might run the engine, barely. Might.
Old Apr 19, 2011 | 12:51 PM
  #27
Sonique's Avatar
Just put the cams back into the engine, with lash caps.. and, it does not start, sounds like it doesn't want to at all! Wihu.. Time to go MS
Old Apr 19, 2011 | 10:09 PM
  #28
! Check the timing and make sure all the sensors are in right. If it still won't even try, I vote for giving the stock cams a chance, just to make sure that is the only reason it won't run. Check the position of the little nub that actuates the cam sensor also.
Old Apr 20, 2011 | 06:14 AM
  #29
Sonique's Avatar
Timing is correct.. all sesors should be okey also.
It makes (sounds like the engine turning faster) some attempt of egnite the mixture occasionally.. but thats all. After a while, fuel steam starts comming out of the air filter.. so mixture and injection timing is probably way off for these cams. Probably just a bit to much to handle for the original ecu.
Old Apr 21, 2011 | 11:16 AM
  #30
Sonique's Avatar
It's alive!
