Cigarette Lighter not working.
Old Aug 27, 2004 | 05:35 PM
planrforrobert's Avatar
Default Re: falken tire Problems
I first noticed that it was not working when I tried to charge my cell phone. I didn't really care at the time, but I am now bought a radar detector on ebay last night and then realized that it gets power from the cigarette lighter. My father and I have had the ash tray console out of the car to install a switch for my amp, and had to disconnect the wires that go to it. I am guessing we did not reconnect it properly. Can anyone tell me how it should go together or what to look for?
Old Aug 27, 2004 | 05:38 PM
tibwrcsbj's Avatar
Default Cigarette Lighter not working.
it will ONLY go together one way......
I dont have my digicam handy so i cant take any pics for you.
Old Aug 27, 2004 | 06:21 PM
Default Re: FS: Custom COLORED Shift Boots!
I will have to mess with it tomorrow and see what is up with it. For all I know, it may have not worked since I bought the car used.
Old Aug 27, 2004 | 07:19 PM
KayJai's Avatar
Default Re: My new Headlight side project.
When you take it apart, Use a test probe to see if you're getting power,...
Then you can see if it's the lighter, or if theres even any power going to it.
Old Aug 27, 2004 | 07:23 PM
JalemX's Avatar
Default Re: Cigarette Lighter not working.
check the fuse
Old Aug 27, 2004 | 08:53 PM
seriously, you should be able to check if the wires are connected in a total of 30 seconds.
pop off shifter surround.
pull towards you on radio surround.
check and see if wires on the back of the ashtray are connected to anything.
Old Aug 27, 2004 | 09:04 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
it seems you already knew why it wasn't working. wasted words, my friend...
and you don't HAVE to set it up through the cigarette lighter.. you COULD wire it to a switch wink1.gif
Old Aug 28, 2004 | 08:02 AM
Default Re: Sanding door and dash
just to add... just because you have power to the lighter... does not mean it works. The one on my Tib, when it was new, did not work. I replaced it so I could use the charger/stand for my cell phone.
Old Aug 28, 2004 | 08:10 AM
Spartacus,
How would you recommend hooking it to a switch? Just cutting off the cigarette adapter and running the power to the battery and then the ground to a ground? I am going to mess with it in a little bit to see what the deal with it is.
Old Aug 28, 2004 | 08:29 AM
Default Re: GK tib brake upgrade !
Yup.
First, check the corresponding fuze.
If it's okay, then take the 2 parts off, the surround and the radio surround, and see if it's plugged ALL THE WAY IN.
If so, look inside the socket to see if it's damaged.
If it's not, test the socket to see if it's getting power.
If it isn't, unplug the lighter at the connector and test it to see if you are getting power.
Simple. If there's no power to the connector, you have a short somewhere or a bad fuse/fuse connections. If it's getting power up to there, you either aren't connecting the connector all the way or you have a burnt out lighter socket. It happens.
