Car shakes at 50-60mph. What could it be?
Old Oct 11, 2010 | 07:37 PM
dckeith18's Avatar
Default Car shakes at 50-60mph. What could it be?
Well a few months ago I got myself a 99 tiburon and ever since I got it seems like the left wheel shakes when giving it gas 50-60mph. Depending on how much gas your giving it the worse it shakes then it seems to stop around 65-70mph. What do you think it could be? I put new tires/balanced on and had a front end alignment and still got the shakes.
Old Oct 11, 2010 | 07:42 PM
are you on stock wheels?
How bad is it?
Old Oct 11, 2010 | 07:46 PM
dckeith18's Avatar
yeah I have stock wheels, The shaking is pretty bad definately noticable shakes my legs lol
Old Oct 11, 2010 | 07:51 PM
if you put it in neutral does the vibration go away
Old Oct 11, 2010 | 07:53 PM
dckeith18's Avatar
Never tried that... I have an automatic =*( Ill try it tomorrow and let you know! but i plan on doing a manual swap but this shaking is driving mee crazy, Any other idea's? My friend thinks its the motor mounts?
Old Oct 11, 2010 | 07:54 PM
Wheel bearings maybe?
Old Oct 11, 2010 | 07:56 PM
if it goes away when you put it in neutral, might internal trans
if it remains, its anything spinnin (axles, wheel bearings, etc)
Old Oct 11, 2010 | 07:57 PM
dckeith18's Avatar
I replaced the wheel bearings and rotor on that side but it could be from the right, you can feel it on sitting in the passenger seat but it seams to be the worse on my side
Old Oct 11, 2010 | 08:00 PM
dckeith18's Avatar
Hopefully its not my transmission but It might be, since its already messed up. Overdrive doesn't work, goes threw 1st 2nd and 3rd then when in 4th its like its in neutral, Drives fine in drive but im guess thats because it never hits 4th gear.
