Car Making Weird Noises When Turning Right
Old Feb 11, 2008 | 11:51 AM
paperstsoapco's Avatar
^^ will do
but as per blanks post my car vibrates when reaching high speeds as well
will update in a couple hours when i head out
Old Feb 11, 2008 | 01:58 PM
AnthonyNTC3's Avatar
a thrown wheel bearing will make a "roaring noise" while driving down the highway. It can also cause a shake too, but that can also be due to a tire out of balance. first try the dry turn test.
Old Feb 12, 2008 | 12:19 AM
UPDATE - when i turn the wheel at a complete stand still i hear the noise still. so bearing it is then.
any idea of about how much this is goin to run me?
o and btw thanks for all of your help guys, it is greatly appreciated
Old Feb 12, 2008 | 07:01 AM
bearings are not that expensive but you would have to get it press fit in
Old Feb 12, 2008 | 08:51 AM
Blank_00Tib's Avatar
Well my car is getting fixed by a nice family friendish mechanic right now and its probably going to cost like 150-160 when all said and done including labour. He had to do a rear wheel bearing already and it cost a little more, like 170.
Old Feb 12, 2008 | 10:17 AM
netsniper's Avatar
Vehicle: uhm..... N/A
Actually if it makes the noise its not the wheel bearing. It is the half shaft. Cause the wheel bearing wouldnt be moving. Secondly on the 2000( I dont know about the other years) the wheel bearing is held in by a snap ring. Do yourself a favor jack up the front of the car and go (with the stearing wheel locked) shake the wheel if one moves more than the other one did, then the wheel bearing is bad. Secondly when your under there look at the cv joint boot.
Old Feb 12, 2008 | 10:41 PM
ok sounds good
i have no room in the garage and its snowing right now so im gonna have to wait a little
Old Mar 8, 2008 | 12:32 PM
as it turns out it was the wheel bearing, thanks for everyones help
Old Mar 8, 2008 | 12:44 PM
Good ya got it fixed. How much did it run ya?
