Budget Power
Old Jan 19, 2007 | 10:36 AM
  #21
Vladimer's Avatar
Vehicle: 01 Tiburon SE
268 cams & ecu will give you more power then the 1.8 cam & ecu? would anyone know about how much?
im probably going to stay na for awhile so i definitely want to peruse this
Old Jan 19, 2007 | 10:46 AM
  #22
Carrera's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>1.8L pistons on 1.8L rods in the 2.0L lowers compression to 8:1 about.
1.8L pistons on 2.0L rods in the 2.0L raises compression to 11:1 about</div>
That doesnt make sense, if 1.8 pistons and 2.0 rods raises compression, then 2.0 pistons on 1.8 rods would lower... logically thats how it should go.. technically I do not know.
Use the search button, the 1.8 cam and ecu have been discussed over and over again in many different posts as well as higher cams.
Old Jan 19, 2007 | 10:51 AM
  #23
hamhead's Avatar
High cams = lots more power than 1.8 cam, 1.8 cam isnt that much of a change from 2.0 cam.
As for what I said, I didn't say anything about 2.0L pistons on 1.8L rods did I? ;p Why doesn't it make sense to you?
Old Jan 20, 2007 | 01:34 PM
  #24
daoust's Avatar
for the na engine with the beta 2liter , 1.8 piston , 2liter rod , beta 2 head gasker ( 2 layers instead of 3 layers) = 11:1 cr , you can find the information on www.kspec.com and www.seoulfulracing.com
for turbo with the 2liter engine , 1.8 piston , 1,8 rod = 7.8:1 to 8.1:1 cr . you can find the information on www.seoulfulracing (forum) and www.ksepc.com
and if you use 2.0l piston with 1.8l rod , you will have less than 7:1 cr , so not enought for turbo , and good for nothing . for info www.seoulfulracing.com (forum)
Now i wish you will stop posting question about this setup and create new false information !!!!!!!!!!!!!!!!!!!!!!!!!
