Hyundai Sonata Forum The Hyundai Sonata Forum. The Sonata (around since 1989) and Hyundai XG300/XG350 (new for 2002) pickup the near-luxury segment for Hyundai. Find out where to get all the luxuries Korea is holding back on (HID, navigation systems, etc.) and how to tune your Hyundai Sonata, Azera, or XG for performance.
Turbo Charging
Old Dec 11, 2001 | 02:12 AM
New TIburon's Avatar
Default Turbo Charging
What exactly is turbo charging? I went on Miro R&D site and they have a turbo charged Sonata. It said they charged to 1800cc. The specs were 230 hp and 32 torque. When you turbo charge do you take a lot of your torque and make it into horsepower or something?
Old Dec 11, 2001 | 02:54 AM
I'm guessing they were not listing hp and torque, but rather Kilowatts and kgf.m
32 kgf.m is approx 231 Ft Lbs of torque.
Can you provide a link to the site you were looking at. I've never seen a 1.8L in a sonata. The smallest sonata motor i know of is the 2.4L.
When turbocharging, (this is an over simplification) you are using the exhaust gas to spin a double fan. One fan is spun by the exhaust gas, the other fan that is connected to the same shaft, sucks air in and compresses it or litterly forces it into your motor.
You should gain both HP and torque when turbocharging and not loose either.
In an engine... roughly 30% of the "power" from combustion is turned into power to turn the crankshaft....30% is absorbed by the coolant system as heat...and 30% gets dumped out the exhaust pipe as hot, high velocity gas.
A turbocharger simply attempts to convert that 30% going out the exhaust pipe into more power...by forcing more air into the engine...so it makes more power...so it makes more exhaust...so it forces more air in, so it makes more power, so it makes more exhaust...repeat cycle!
Old Dec 11, 2001 | 07:50 AM
BlueGT's Avatar
Vehicle: 2004 Tiburon GT
Random, I've seen Sonatas with 1.8L in Asia. Those were 2nd gen (called Sonata II in Asia).
Old Dec 11, 2001 | 01:23 PM
2003 Tiburon's Avatar
the site was miroauto.com, but you'll have to find the right page cause it's all in korean.
Old Dec 12, 2001 | 06:58 AM
Cheuk in Seoul's Avatar
The Miro Sonata is running a 1.8 L Beta.. it is the base option for the Newest generation Sonata. The HP is in DIN hp (metric) and the torque is in Kg-m.. multiply by 7.216 to get ft lbs.
Old Dec 12, 2001 | 01:30 PM
Here is the page
http://www.miroauto.com/sub51.asp?sub=51&dis4=block
They also have a New tibby http://www.miroauto.com/sub52.asp?sub=52&dis4=block
