Hyundai Sonata Forum The Hyundai Sonata Forum. The Sonata (around since 1989) and Hyundai XG300/XG350 (new for 2002) pickup the near-luxury segment for Hyundai. Find out where to get all the luxuries Korea is holding back on (HID, navigation systems, etc.) and how to tune your Hyundai Sonata, Azera, or XG for performance.
tire pressure monitoring?
Old Feb 23, 2011 | 03:04 AM
brassmunkeyz's Avatar
Vehicle: 2011/hyundai/sonata
Default tire pressure monitoring?
will having the tire pressure monitor system make it difficult to change rims?
Old Feb 23, 2011 | 04:50 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
Shouldn't be a problem
The actual sensor is part of the valve stem (on hyundai's)
The only problem i would see is the guy mounting the tires. The sensors are very fragile and low pro tires can be a b*tch to take off/on. When the 2 are combined the guy at the machine better know what hes doing.
The sensors cost $70-$100 each
Old Feb 23, 2011 | 08:00 AM
You can swap them between rims, just make sure the guy mounting them is aware. Some cars have had them for years (Monte Carlos) and many manufacturers are including them now to comply with legislation. It shouldn't be the first time they've worked with them before, but it's a good idea to let them know when you change your tires/rims.
Old Feb 23, 2011 | 01:56 PM
would it cost more for labor if they have to be aware of the pressure system?
Old Feb 23, 2011 | 02:25 PM
It shouldn't. Most places should have standard pricing. If they try to charge you extra, go to a reputable shop.
Old Feb 24, 2011 | 07:58 AM
SR Tech's Avatar
Its getting to the point where they are going to look first anyways. The ones that are part of the valve stem are easily identified. The other style (fords mainly) wrap around the outside of the rim with a metal band. Which can be seen when your break the bead.
Any car 2006+ is required to have this system
Old Mar 17, 2011 | 02:30 PM
newgenesis's Avatar
Vehicle: 2011 Hyundai Sonata SE
Thats not completely true my GF has a 2006 Nissan Sentra and it doesn't have TPMS.
Old Mar 17, 2011 | 06:04 PM
SR Tech's Avatar
It maybe labeled as an 06' model but most likely was manufactured in 05'. That's why you'll see 2012 models in showrooms probably around spring/summerish of this year.
Neither here nor there but figured id point it out
