tire pressure monitoring?
will having the tire pressure monitor system make it difficult to change rims?
Shouldn't be a problem
The actual sensor is part of the valve stem (on hyundai's) The only problem i would see is the guy mounting the tires. The sensors are very fragile and low pro tires can be a b*tch to take off/on. When the 2 are combined the guy at the machine better know what hes doing. The sensors cost $70-$100 each :thumbup: |
You can swap them between rims, just make sure the guy mounting them is aware. Some cars have had them for years (Monte Carlos) and many manufacturers are including them now to comply with legislation. It shouldn't be the first time they've worked with them before, but it's a good idea to let them know when you change your tires/rims.
would it cost more for labor if they have to be aware of the pressure system?
It shouldn't. Most places should have standard pricing. If they try to charge you extra, go to a reputable shop.
Its getting to the point where they are going to look first anyways. The ones that are part of the valve stem are easily identified. The other style (fords mainly) wrap around the outside of the rim with a metal band. Which can be seen when your break the bead.
Any car 2006+ is required to have this system |
Originally Posted by SR Tech
(Post 618599)
Thats not completely true my GF has a 2006 Nissan Sentra and it doesn't have TPMS. |
It maybe labeled as an 06' model but most likely was manufactured in 05'. That's why you'll see 2012 models in showrooms probably around spring/summerish of this year.
Neither here nor there but figured id point it out |
