Hyundai Sonata Forum The Hyundai Sonata Forum. The Sonata (around since 1989) and Hyundai XG300/XG350 (new for 2002) pickup the near-luxury segment for Hyundai. Find out where to get all the luxuries Korea is holding back on (HID, navigation systems, etc.) and how to tune your Hyundai Sonata, Azera, or XG for performance.
View Poll Results: whats the recommended weight oil for my 2001 sonata 4 cyl
did I get the wrong weight and type oil
100.00%
bring it back the oil
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
the right oil for my 2001 4 cyl
Old Feb 1, 2011 | 04:08 AM
SUZONKA's Avatar
Vehicle: 1999/hyundai/accent
Default the right oil for my 2001 4 cyl
I purchased a 5 qt container of 5x30 castrol, now I'm wondering if I should change it to 10 x30 Quaker state? for My 2001 4 cyl sonata 120 ,00 miles on it runs real good
Old Feb 1, 2011 | 06:45 AM
I would switch it to 10w30. Where are you located at? Depending on what type of hot or cold weather your area gets, will also determine what weight oil you should be using too.
Old Feb 1, 2011 | 11:53 AM
SUZONKA's Avatar
:biggrin:
well the last four weeks have been in the 20's but will go up to 40 in about 3 weeks to month can I use the 5x30
Old Feb 17, 2011 | 11:18 AM
rallyman's Avatar
For your car Hyundai recommends 5W30 oil for temperatures 50F and below. If you will see temps above 50F before your next oil change (which is likely since spring is just around the corner) its probably better to go with the 10W30. For your engine the 10W30 is safe for a temperature range of -13F up to 104F.
Old Feb 19, 2011 | 12:11 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
5W-30 is recommended up to a maximum of 95 degrees F. So, you'll be fine running that.
Old Mar 23, 2011 | 11:03 PM
SUZONKA's Avatar
would it be OK to use a 15x30 weight the temperature will go up to 70 f in a week
File Type: jpg
Old Mar 24, 2011 | 01:12 AM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
I personally run 20-50 oil in my Tib now, all year round, also i live in washington and have never had lifter tick or anything EVER! I do allow my car like 5 minutes warm up no matter the temp, and it doesnt see any higher than like 2500 rpms till i see the temp gauge normal. Yet, i do beat my car when it gets driven, so I put that oil to work.
Old Mar 24, 2011 | 04:08 AM
SUZONKA's Avatar
Is you car a 4 cyl and does it have turbo ,mine is a 4 and no turbo,oh are you useing a synthetic oil , Im useing regular oil if that makes a difference I change it every 3000 miles anyway. also what does the manual recomend for your car 10x40 max ? mine is 5x30 to 10x30
Old Mar 24, 2011 | 01:03 PM
Yep, I have the 2l 4cyl. Yet mine does have a ton of work put into it, and doesnt get driven alot. Yet, also i am still using a high grade conventional oil. Also I am turboed, hints to the very heavy wieght, were a 5w30 oil would just break down from heat, and would not be able to do it job as OIL.
For you I would say 10w30 is a good summer oil weight, you should have no problem, Also I love Catrol GTX 10w30 like 15 dollars for 5 quartz at WallyWorld!!! GTX FTW!!!
Old Mar 24, 2011 | 03:26 PM
Castrol vs. Quaker State, don't worry about that both brands are fine.
You can run the 5w30 oil with no problems. I would recommend 10w30 for your next oil change. 5w30 starts out thinner than 10w30 but at operating temperature they're both the same viscosity.
