Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
What 4G63?
Old Dec 11, 2002 | 06:43 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
Default What 4G63?
Ok, I'm gonna swap a 4G63 in my 98 Elantra. Yeah I know it doesn't bolt in and everything but I can't find a damn Beta in this country so I'll go 4G63. So what type of 4G63 should I put in? What is the best kind of 4G63 (besides EVO motor)?
Old Dec 12, 2002 | 01:31 AM
Red's Avatar
Red
You have to go EVO, because it has to face the proper direction when you swap it. A "normal" 4G63 that would fit in a turbo Eclipse would be a severe pain in the *** ...
As to which EVO engine to use, I dunno. Pick a number between three and seven wink
Old Dec 12, 2002 | 02:38 AM
turbulence's Avatar
go to www.car-parts.com it's a pretty good site. i used it to get parts for my auto-manual swap. they have plenty of betas, some for $250.
Old Dec 12, 2002 | 03:05 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>turbulence:
go to www.car-parts.com it's a pretty good site. i used it to get parts for my auto-manual swap. they have plenty of betas, some for $250.</div>Lantraluver is in the phillipines, you gotta keep that in mind when giving him advice.
Old Dec 12, 2002 | 05:37 PM
lantraluvr's Avatar
I was wondering, why does it have to face the 'right' way? Why not swap a 'normal' 4G63?
BTW, last time I checked, an EVO 4 front cut costs around $4000 here. I can only afford a 'normal' turbo 4G63 ($1000). Besides, installation at my bro's friend's shop is only at $300.
Old Dec 12, 2002 | 06:40 PM
Shadohh's Avatar
He has a point. you should not need to make it face the correct way.
I mean wether its a Evo engine or a normal 4g63. You will sitll need to fabrivate some parts.
Yes its easier with the Evo since the tranny is on the driver side.
But if he got a normal 4g63 with the tranny on the passenger side. They hace factory cars like that.
so the brake pedal and clutch and other things should transfer right over.
Old Dec 14, 2002 | 09:08 AM
lantraluvr's Avatar
So what should I look for/do in swapping the engine in?
Old Dec 14, 2002 | 09:19 AM
Shadohh's Avatar
Well, in the US, when you are facing the front of the car, the driver side is on the right.
so the transmission is on the right.
the 4g63 in the US has its transmission on the left (elcupse, galant, few otherS)
The lance evolution, have their transmission on the right.
so, is your driver side, right or left when facing the car?
Old Dec 14, 2002 | 10:49 AM
lantraluvr's Avatar
Same as you guys, we're Left Hand Drive here too. The driver's side here is at the right when facing the front of the car.
Soooo... what was your point there?
