Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
mistu swap
Old Nov 12, 2001 | 04:52 PM
xpressedhyundai's Avatar
Default mistu swap
Tryin to find info on an eclipse motor swap into a 99 elantra. is it posible ifso what yr eclipse and what mds may be needed.
*** NOT tying to get gs-t. ***
Old Nov 12, 2001 | 10:54 PM
DESIGN's Avatar
You may be under the impression that the two engines are bolt in replacements for each other. You are looking at doing a custom fab-up. You will also need all the mitsu's drive train and ecu. It would be cheaper to find out how to improve your beta.
Old Nov 13, 2001 | 12:01 AM
Phantom's Avatar
Vehicle: 99 tiburon
Yeah, what Design said
Old Nov 13, 2001 | 01:56 AM
bluedream-
It is possible, but not easy or cheap. The older elantras had mitsu motors but 1996 and newer are hyundai motors, so the swap is a major pain.
For the cost, you would be better off to improve the existing beta motor with a turbo charger.
Old Nov 14, 2001 | 03:22 AM
Brendan's Avatar
the mitsu motor is backwards to ours, it won't even blot up, and to get it in you'll need to swap everything around in there.
