Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
J0eFr0's Swap
Old May 30, 2008 | 08:01 AM
capn tibs's Avatar
Vehicle: 2001 Tiburon
you can easily get your compression to 7:7:1 if you want to with p & p, 1.8 cam, 1.8 ecu and a few other things. I think caj darkmoon or someone did a DIY for doing your own P&P work. It really is mostly time with a dremel tool and sandpaper and since you pulled your own engine I would think you could do it yourself.
Running 20-25 PSI is high on a Beta 1 engine. You can find several tibs on RDT running high PSI on stock engines. Most seem to run in the 16-17 range on stock compression but some test the waters with higher numbers. I don't believe there are many that boost over 20 regularly.
Old May 30, 2008 | 08:47 PM
J0eFr0's Avatar
Vehicle: 2000 Hyundai Accident
i'd rather a professional port and polish it for me, since i've read if you don't do it the right way it'll have a negative effect rather a positive one.
Old May 30, 2008 | 10:14 PM
342Four's Avatar
Vehicle: '97 X3
theres a guy here in Aus with a built LC2 thats running 22psi on a garret turbo and an external wastegate
think its got forgies in it to around 8:1 compression
makes about 220hp if i remember rightly - best 1.4 mile of 12.8
Old Aug 20, 2008 | 10:08 AM
Ilovmyaccent's Avatar
Vehicle: 2001 Hyundai Accent GS
hey your just gonna do the 1/4 mile right? i dont know what psi this guys is running but he makes 9.42 @ 142MPH in his accent! found it on youtube and thought you might like to see it.
http://www.youtube.com/watch?v=6jvDg6gtOF8
Old Sep 11, 2008 | 09:20 PM
Jeremy's Avatar
Vehicle: 02 Hyundai Accent GS
^^ That Accent is pushing 500hp awd and it isn't a beta engine it's a Mits I believe and completely stripped.
