Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
engine swap
Old Jun 18, 2002 | 08:59 AM
Shadohh's Avatar
rx7 engine will be so hard, you would have redo the chassis and convert the car to rwd.
With the lancer evo engine, it is AWD, basically like a FWD with tacted on rwd. You just eliminate the rwd functions.
Old Jun 18, 2002 | 09:11 AM
Dopeskills's Avatar
Would the RX-7 swap 'have' to be RWD?
Heh, if the swap were that easy I would have done it already. (My dad's shop sells supercharged rotary engines).
Old Jun 18, 2002 | 03:24 PM
Shadohh's Avatar
I never heard of a supercharged rotary.
only turbo.
Umm, Well you would have to find a fwd transmission for the rotary engine. As far as I know all the rotarys cars arw rwd. I understand mazda shares alo the deisgns between their cars and some fords, maybe you can find one.
I doubt it.
Old Jun 18, 2002 | 11:30 PM
Dopeskills's Avatar
The engines are very compact so I would assume that it doesn't have to be mounted longitudinal.
The supercharged rotary (Mazda) is set up for use on a boat. I could post a pic you want.
Old Jun 18, 2002 | 11:42 PM
JP's Avatar
JP
Vehicle: 1998 Accent
There was an NSU (Audi) back in the '70s that used a wankel rotary engine with front wheel drive, but pretty rare to find (possible tranny source).
Old Jun 19, 2002 | 12:05 AM
Veniston's Avatar
<div class='quotetop'>QUOTE</div><div class='quotemain'>Dopeskills:
The supercharged rotary (Mazda) is set up for use on a boat. I could post a pic you want.</div>Sounds interesting, I just looked into it and apparently there is a fair sized marine market for rotary engines. Do you know how much crank horsepower the supercharged unit is making?
I'm planning on a boat some day too, that setup would be awesome
Old Jun 19, 2002 | 02:39 AM
Denisst99's Avatar
If the problem is only mounting the rotary engine to the existing tranny someone could make an adaptor plate to mate both of them together...
an hybrid clutch disc will be needed too
One guy arond here owns a kit car with a cadillac STS engine (4.6 32 valves) with a Audi tranny to get a centrally mounted engine (just like the real car)
So it can be done for sure
Denis
Old Jun 19, 2002 | 03:43 AM
Shadohh's Avatar
Anything can be done, it just costs $$$
Anythings from a Viper Engine in Caravan minivan
to a v8 on geo metro
make your tiburon swim with am amphibous mode.
turning a fiero gt into a lamboghini
Old Jun 19, 2002 | 05:12 AM
use this motor
Old Jun 19, 2002 | 06:26 AM
Dopeskills's Avatar
Autobot should buy that thing. He would have the fastest 'sea foam' colored nissan out there.
