Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Engine swap
Old Sep 15, 2002 | 04:06 PM
JoElantra's Avatar
Default Engine swap
I have the 1.8 '97 Elantra. I would like more displacement. So, my question is how much of a pain will it be to put in the 2.0 out of a tiburon or elantra? Would i need the 2.0 trannies, ecu, mounts, etc. I see engine on ebay going pretty cheap occasionally, and was wondering if it would work without too many problems. Thanks.
Old Sep 16, 2002 | 02:07 AM
The swap should be straight forward. If you go with the "XD" Beta2 motor, the swap is a tad more complicated, as the flywheel mounts slightly differently, but other than that, no problems.
The 2.0/1.8 share the same block, mounts trannies, etc..etc..etc..
[ September 16, 2002, 09:10 AM: Message edited by: Random ]
Old Sep 16, 2002 | 07:28 AM
JAWS 021's Avatar
If your going to swap the engine... you might as well switch the pistons and turn it into a project motor
Get direct port, turbo, or supercharger later
The engine would be good up to 300whp
You could also do some headwork, and other fun stuff wink
Old Sep 16, 2002 | 01:54 PM
JoElantra's Avatar
I wouldn't need to switch the ECM!! that is a main concern. There is an engine on ebay right now out an elantra i think it's a 99-00, no problems?? postive???
Old Sep 16, 2002 | 08:36 PM
Angelos's Avatar
Vehicle: 01 Tiburon
Do the swap and after some reinforcement such as pistons,rods etc in order to be able to boost your elantra and show taillights..But if you are planning to turbo your elantra its better to do it with the 1.8ltr moter..Ive heard that 1.8s are better for turbo applications....
Old Sep 17, 2002 | 01:20 PM
JoElantra's Avatar
How is the 1.8 better for turbo applications? plus i don't think a 1.8 or 2.0 with 110k miles on it is good for turbo or nitrous with out thousands upon thousand of dollars worth of work. i don't have that thick of a wallet, if you know what i mean.
Old Sep 17, 2002 | 02:31 PM
Shadohh's Avatar
Not really, I would rebuild the engine with new internals and it should be good to go. Remember its an iron block. And everything else just need to be swapped.
I seen hyundais with 230k miles on them. sitll run strong.
Old Sep 17, 2002 | 02:43 PM
J@WS 01's Avatar
I beleive the ECUs are different and so are the fuel injectors.
