Dodge Spirit Engine swap
If I were to go with a bastard engine swap, I'd find a much better supported engine than a Dodge Spirit motor.
The Mitsubish 4g63 comes to mind as a much more powerful motor with much better mod potential, and much better support.
<div class='quotetop'>QUOTE</div><div class='quotemain'>Random:
The Mitsubish 4g63 comes to mind as a much more powerful motor with much better mod potential, and much better support.</div>I hear a lot about 4g63, are the mounts similar? Are there any major problems with the swap? Do you keep the mistu tranny or use the tibby tranny?
Jester do a search on that subject and you will find that there are plenty of issue. The least of which is that most other engines are rotated 90 degrees to what Hyundai has done (the tranny is on the other side).
