Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
beta swapped trouble with o2
Old Jan 6, 2010 | 06:30 AM
superman3000's Avatar
Vehicle: 1999/hyundai/accent
Default beta swapped trouble with o2
i have a x3 beta swapped accent, i havent been able to figure out why my o2 sensors are throwing cel's. i took to autozone and the codes are o2 malfunction. has anybody else had this problem and what fixed it?
Old Jan 6, 2010 | 01:17 PM
Knowing which code(s) exactly would be helpful.
Old Jan 6, 2010 | 01:36 PM
ereeves116's Avatar
Vehicle: 2002 Accent
yeah which codes?
which O2 sensors are you using, what year is the beta, what ECU are you using?
give us some more info. i'm sure we can help out. I had the same problem at first with my swap and you know what it was? broken O2 sensor. could be a possibility...and without more info, can't tell you
Old Jan 12, 2010 | 06:53 AM
dont recall what the code was i could go back and get again. but the explanation was bank 2 o2 malfunction. but i have thrown o2 cels since i first swapped. i have a 99 accent with 99 beta and matching ecu.
Old Jan 12, 2010 | 09:18 AM
rooney10's Avatar
Vehicle: 2002 Hyundai Accent GS
I had the same code being thrown last year because of the amount of fuel had damaged the o2 sensor. I bought a new one and that had solved the problem. It was the second o2 sensor I had to replace.
