Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Beta 1 in 1.5L accent LC ?
Old Jan 19, 2010 | 02:46 PM
It's just a guess, but I would say that you would probably lose 5-10peak hp with it fully retarded, but no or minimal loss of peak torque.
If you can find the voltage range you could always just feed it a steady voltage, that's pretty easy to set up. If you wanted to be fancy you could make something that varied the voltage by RPM or vacuum.
Old Jan 19, 2010 | 03:06 PM
warp21's Avatar
Vehicle: 2000 Hyundai Accent
CVVT uses pulse width modulation with cam sensor and oil temperature feedback to accurately adjust the timing, it uses a very complex map. However you could use an rpm switch and have it kick all in at a certain rpm (like vtec?). BTW the signal wire requires a low or ground to activate.
Old Jan 19, 2010 | 03:21 PM
patdeman's Avatar
Vehicle: 2000 hyundai accent GS 1.5L
that vtec idea sounds great, how could i get a voltage out of an rpm range tho ?
Old Jan 19, 2010 | 03:47 PM
warp21's Avatar
You would need to use an rpm activated switch. MSD maybe? When the desired rpm is reached you would want to send a ground signal to one terminal on the solenoid. The other would be wired to same 12v that controls the fuel pump or main relay. You also may consider adding some conditional logic like only having it activate at WOT and RPM.
Old Jan 19, 2010 | 04:12 PM
patdeman's Avatar
yea i think il get a MSD RPM activated switch but does the cvvt run on 12v ?
Old Jan 19, 2010 | 04:13 PM
warp21's Avatar
Yeah 12v.
Old Jan 19, 2010 | 04:40 PM
patdeman's Avatar
allright sounds simple enough, il prob lose a lil power from not having it thru the whole rpm range but it should be pretty interesting to have it kick in at a certain rpm.
Old Feb 15, 2010 | 07:30 PM
patdeman's Avatar
the engine i bought uses a maf sensor, can i just plug it directly into the wiring harness ? or do i have to convert to map ?
Old Feb 15, 2010 | 07:53 PM
You're going to want to convert it to MAP. What year and car did you get the engine from?
Old Feb 15, 2010 | 08:46 PM
patdeman's Avatar
2004 hyundai elantra 2.0L CVVT
