Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Beta 1 in 1.5L accent LC ?
Old Jan 16, 2010 | 08:10 AM
patdeman's Avatar
Vehicle: 2000 hyundai accent GS 1.5L
Default Beta 1 in 1.5L accent LC ?
Whats would be different in putting an beta 1 instead of a Beta 2 in my lc accent (2000, 1.5L). Can it be done as easily as a beta 2 swap ? and is the beta 2 engine much better ?
Old Jan 16, 2010 | 08:38 AM
Schwitzer Turbo's Avatar
Vehicle: 1995 Scoupe Turbo GTR
<div class='quotetop'>QUOTE (patdeman @ Jan 16 2010, 05:10 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Whats would be different in putting an beta 1 instead of a Beta 2 in my lc accent (2000, 1.5L). Can it be done as easily as a beta 2 swap ? and is the beta 2 engine much better ?</div>
hello my friend. I am pretty much asking the same questions as you. Check out my two threads in this hybrid forum section. At present i dont believe there will be a difference between installing a beta 1 or 2. Unless you have a beta 2 with CCVT. Then there might be some electrical wiring differences. . . I was keen on a beta 2 purely because it was newer and according to wikipedia the was sum architicaul impovements yet performance stayed pretty much. The same. But now im keen on the beta 1 as according to wikipedia it has forged steel connecting rods which will be awesome for me cause i will turbo this lump and i have broken conrods before. . . .
Old Jan 16, 2010 | 02:51 PM
Read this: Beta I vs. Beta II
And read this: Beta I to Beta II swap in a RD Tiburon
For extra info, the 00-05 1.6l ECU can read the signal from most of the Beta II sensors, so swapping to a Beta I would require either buying and installing the Beta II sensors, buying and trying to install 1.6l sensors, running on a standalone, or rewiring using a Beta I car's harness. Also, unless you're fabbing parts to make the IM from the Beta I work with a MAP sensor, you would need to get a Beta II IM.
In the end, not worth the trouble at all IMO, even if you could get a Beta I for free. That's why I turned down 2 free Beta I engines.
Old Jan 16, 2010 | 07:26 PM
patdeman's Avatar
Old Jan 16, 2010 | 08:37 PM
ereeves116's Avatar
Vehicle: 2002 Accent
in the end stay away from CVVT. I couldn't figure out how to wire mine properly and had to have a shop finish up for me. It is fun though when it kicks in (holy sh*t vtec just kicked in!)
Old Jan 17, 2010 | 08:14 AM
patdeman's Avatar
how much did it cost you to get it done at the shop ? (cvvt) and also, cant u buy a cvvt and just not plug the cvvt in ?
Old Jan 18, 2010 | 06:26 PM
patdeman's Avatar
i found a REALLY good deal on a beta 2 cvvt engine, 60000kms, can i just not plug in the cvvt ? are all the other sensors the same as a non-cvvt?
Old Jan 18, 2010 | 06:40 PM
patdeman's Avatar
also, i bought headers for a 2003-2004 tib, will they fit on the cvvt engine ?
Old Jan 18, 2010 | 06:53 PM
The header will fit the non-CVVT or CVVT engine.
You technically might be able to get the car to run without the CVVT hooked up, but it's not ideal at all. You would have to look at the wiring and see if you can figure out how to lock it at the most desirable position, probably fully advanced. It's just a guess, but I'm thinking that if it's not hooked up it's probably fully retarded.
Old Jan 19, 2010 | 02:31 PM
patdeman's Avatar
will a cvvt engine locked in fully retard be less powerfull then a non-cvvt engine by much ? also, can normal cams be put in the engine and cvvt mechanism removed ? (and yes, from what i can understand off hma service, its gonna be locked fully retarded)
