Stock wastegate
Vehicle: '10 Genesis Coupe 2.0T
Stock wastegate
Is the stock wastegate adjustable? I was under the impression that it wasnt but someone told me that all wastegates whether they are stock or aftermarket have some level of adjustability to them.
i don't have a gcoupe or have seen a WGA on a gcoupe, but I am going to say that it is probably NOT adjustable.
The actuator arm probably has a fixed length (making it non-adjustable)
do you have a picture of the stock WGA? should be pretty easy to tell if you have one..
If not, you can always get a boost controller.
Vehicle: 2010 Hyundai Genesis Coupe 2.0T Premium
Replace the stock wastegate/bov. IT leaks. only bueno for 16psi. If you tune the car its useless. You can do two twists to the actuator arm and helps the valve snap open faster. I wouldnt advise doing this if you're already tuned.
