Hyundai Genesis Forum The Hyundai Genesis Forum. An area for the all new generation RWD Hyundai sports coupe and sedan.
Resurfacing Dual Mass Flywheels
Old Jul 7, 2013 | 05:38 PM
2.0gennycoupe's Avatar
Vehicle: 2011 Genesis 2.0
Default Resurfacing Dual Mass Flywheels
I know regular flywheels, you can have them resurfaced when you change your clutch. But can you resurface dual mass ones? Is it basically the same process or is there more to it?
Old Jul 7, 2013 | 07:02 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I have heard it is possible if you find someone that knows how to deal with the friction surfaces ability to move a bit. However, I would be worried that our DMFs spring is worn out and the effort would be wasted. Mine has a good bit of movement/noise to it at 70k, its not going back in. I am probably going to dump it and go with a SPEC flywheel/clutch once its time.
Old Jul 7, 2013 | 08:50 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Idk if its possable.. Because the flywheel moves inside itself with springs. Im pretty sure there made to never be taken apart. so to machine something that cant be clapped down seems hard to me.
Old Jul 7, 2013 | 09:42 PM
This seems like a question for your local machine shop
