Hyundai Genesis Forum The Hyundai Genesis Forum. An area for the all new generation RWD Hyundai sports coupe and sedan.
Outside temperature
Old Jul 9, 2013 | 01:15 PM
darthvadergenesis's Avatar
Default Outside temperature
Where is the sensor located at on a Genesis that reads the outside temperature? I often wondered that when I see the temp on my dash screen and how it worked exactly.
Old Jul 9, 2013 | 02:02 PM
I believe it's above the intercooler. When your intercooler heatsoaks I've seen the temps rise
Old Jul 10, 2013 | 10:16 AM
Red Raspberry's Avatar
If you have the display on the screen there are two sensors. One for the ECU and one for the display. They are by the horns. I moved mine up so as not to be behind my IC.
Here is the stock location, the PS cooler has been moved up here.
As you can see they are behind the IC now.
Here is where I moved them.
And where they are after moving with IC installed.
