Clutches/Flywheel: Information Collection
Vehicle: 2010/Hyundia/Genesis Coupe 2.0T Track
I wanted to make a thread and I need peoples help to minimize my searching time and help everyone out when they are looking to buy one. Please correct me if I am wrong I will try to edit it. I am looking to get a new clutch and it is a pain flipping through so many threads and sites. I helps to make an educated descision based on specs from a consolidated list.
I don't really want to get a bunch of opinions or reviews or experiences with brands ect. in this thread, this is purely for facts/specs/info please. You come here, look at the specs, find what you like, narrow it down and THEN you can do a search on the forum or make a thread to check on their reputation, chatter, and other info that could help you decide.
Flywheels weight:
OEM DMF: 30 lbs
Exceladyne SMF (Chromoly): 13.6lbs
Exedy SMF (Chrome molly steel): 40lbs (Clutch/FW)
Clutchmasters SMF: 22 lbs
DTMSPEED SMF (alum backing Chromoly face): 17 lbs
SpeedyHouse SMF: ?
SPEC SMF (alum backing replacable face): 16.7 lbs
Competition SMF (Steel): 16lbs
Clutch materia/Torque rating max (crank lb ft) (or % over stock crank tq):
OEM: Organic/250-350 lbs seems to be people report slipping but if anyone actually ahs specs, please inform me.
Exceladyne Twin Disc Clutch: Unsprung Ceramic Disks/560lbs
Exedy's new Twin Disk: ?/?
SpeedyHouse Twin Disk: Unsprung Ceramic 6 Puck/?
DTMSPEED Stage 4 Clutch: 5 or 6 puck ceramic-cintered/ 650 lbs
SPEC Stage 1: Steel-backed and multi-compound woven organic material/420 lbs
SPEC Stage 2: Pure Kevlar friction material/490 lbs
SPEC Stage 2+: Hybrid Kevlar and Carbon-Graphite Friction material/543 lbs
SPEC Stage 3: Carbon-Graphite Friction Material/616 lbs
SPEC Stage 3+: Carbon semi-metallic friction material/688 lbs
SPEC Stage 4: Carbon-Graphite Friction Material/616 lbs
SPEC Stage 5: Full-metallic friction material/815 lbs
ClutchMasters Stage 1: Steel-Backed Organic/70% Increase
ClutchMasters Stage 2: Full Faced Kevlar/70% Increase
ClutchMasters Stage 3: Segmented Kevlar/110% Increase
ClutchMasters Stage 4: Ceramic 4 Puck or Ceramic 6 Puck/170% Increase
ClutchMasters Stage 5: Unsprung Ceramic 4 puck, 6 puck, or sintered iron/200-400% Increase
Competiton Clutch Stage 2: Steelback Brass/80% Increase
Competiton Clutch Stage 3: Segmented Kevlar/150% Increase
Competiton Clutch Stage 3: Segmented Ceramic/150% Increase(long life than Kevlar)
Competiton Clutch Stage 3: Iron 6 Puck/175% Increase
Competiton Clutch Stage 4: Sprung or unsprung Ceramic 6 Puck/250% Increase
Competiton Clutch Stage 5: Sprung or unsprung Ceramic 4 puck/300% Increase
PP Material/Force:
OEM : ?/1200lbs
Exceladyne: ?/?
Exedy: 500-600tq, with sprung ceramitallic friction plates
Clutchmasters: ?/?
DTMSPEED : Aluminum/2200-2400 lbs
SpeedyHouse: Aluminum/?
SPEC: ?/?
Competition Clutch: Steel/2700lbs
Price:
Exceladyne Twin Disc Clutch + PP + Flywheel: ~$2300
Exedy's new Twin Disk + PP + Flywheel: $1800
SpeedyHouse Twin Disk + PP + TOB: Projected $1600-$1900.
DTMSPEED Stage 4 clutch + PP + Flywheel: $1600
SPEC Flywheel: $530
SPEC Stage 1+ PP: $500
SPEC Stage 2+ PP:$546
SPEC Stage 2+ + PP:$560
SPEC Stage 3+ PP:$530
SPEC Stage 3+ + PP:$646
SPEC Stage 4+ PP:$530
SPEC Stage 5+ PP:$700
ClutchMasters flywheel: $960
ClutchMasters Stage 1+ PP: $575
ClutchMasters Stage 2+ PP: $645
ClutchMasters Stage 3+ PP: $645
ClutchMasters Stage 4+ PP: $645
ClutchMasters Stage 5+ PP: $575
Competiton Clutch Stage 2 + PP: $895
Competiton Clutch Stage 3 + PP: $995
Competiton Clutch Stage 3 Ironman + PP: $995
Competiton Clutch Stage 4 + PP: $895
Competiton Clutch Stage 5 + PP: $895
Competiton Clutch Ironman + PP: $995
DMF= Dual Mass Flywheel
SMF= Single Mass Flywheel
I am not going to classify any ALF (aftermarket lighweight flywheel) as that is really subjective. The weights are listed, you decide if it is a SMF or ALF.
PP=Pressure Plate
TOB= Throw Out Bearing
Flywheels weight:
OEM DMF: 30 lbs
SpeedyHouse SMF: ?
PP Material/Force:
OEM : ?/1200lbs
Exceladyne: ?/?
Clutchmasters: ?/?
SPEC: ?/?
Price:
SPEC Flywheel: $530
PP=Pressure Plate
