Adjusting speedo for different size rims and tires
Old Oct 5, 2011 | 03:00 PM
TunedElantra's Avatar
Vehicle: 2003 Turbo Elantra
Default Adjusting speedo for different size rims and tires
Is there any way to adjust a speedometer for bigger sized rims and tires that are not stock? I think there are programmers out there for trucks that plug into the ecu ports to adjust for non-oem rim and tire sizes. Didnt know if there programmers for Hyundais too.
Old Oct 6, 2011 | 06:53 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
I am also interested in this as well, hope someone knows.
Old Oct 6, 2011 | 08:57 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
I don't see the point? I have 16" rims on my Accent and my speed o can't be off by more than 5 mph at higher speeds. I could understand the need if you have GIANT tires on your truck, but for our cars, I say forgetaboutit.
Old Oct 6, 2011 | 09:08 PM
The problem comes in when your tires' outside diameter changes by an inch or more. Normal tire tread wear will be at least that much of a difference, from fresh to worn-out tires. The WHEEL has very little to do with the whole question, unless they are too big to fit a tire in something like the stock tire diameter.
Old Oct 6, 2011 | 10:28 PM
HotBlue02's Avatar
Well in my case I have a few things going on, like the elantra trans feeding an LC2 gauge cluster in an LC. I found that with 205/50R16 the speedo is perfect but thats a bit to much sidewall for me so I went from 50's to 45's. This has me off by 5mph, for instance if my speedo says 70mph im doing 65.
Old Oct 7, 2011 | 10:07 PM
Did you use highway mile markers to measure or ???
This could be a good time to print up some custom gauge faces with a speedometer calibrated for your setup.
Old Oct 8, 2011 | 06:14 PM
HotBlue02's Avatar
I used the electronic speed displays that are all over california for measuring my speed.
Old Jan 22, 2012 | 03:31 AM
300D50's Avatar
I can look into making a converter/rescale box that goes between the speed sensor and the rest of the harness if you guys think it's marketable.
Old Feb 9, 2012 | 08:18 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
when upgrading to bigger wheels and tires..it's recommended to stick with "plus sizes"
or a tire that has the same diameter of the oem size tire..
